Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Jun 24, 2016 | 02:49 AM
  #451
houtslager's Avatar
houtslager
thanks, but do I have a 3.55 axle, how do I check this out ?
Old Jun 24, 2016 | 10:32 AM
  #452
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Post the TRANS & AXLE codes printed on the Certification Label, glued to the left door face below the latch.
Old Jun 24, 2016 | 10:37 AM
  #453
houtslager's Avatar
houtslager
will do when I get to the van. Will post the info Sunday if possible, thanks for the tip
\K
Old Jun 24, 2016 | 09:50 PM
  #454
hawkdog's Avatar
hawkdog
VIN Decode please
Was given this truck, now I need to find info on it...
F65CVM80181 *CAB-CHASSIS*
GVW1800
NET HP 164
RPM3800
WB 156
MODEL F53
BODY 4 8
TRANS P
AX 62
DSO(?) 731284
Rockwell diffs- Frnt - 6.2 FDS75 HDX6 Rear - 6.2 F106 BNX2
Transfer case - 587 5P432 It has 2 shift levers and 1 drum style brake
tranny - N1 is all I could find, on the drivers side
Thanks for any help,
djhawk
Old Jun 25, 2016 | 09:18 AM
  #455
NumberDummy
F65CVM80181 / WB: 156 / COLOR: Blank* / MODEL F653 / BODY: 4 8 / TRANS: P / AXLE: 62 / MAX GVW LBS: 18000 / CERT NET HP: 164 / RPM: 3800 / DSO: 731284
Welcome to FTE
The above codes were rearranged as to how they appear on the Warranty Plate.
F65 = F600 4WD (gas).
C = 330 2V Medium Duty FT engine.
V = Kentucky Truck Assembly Plant.
M80181 = 1972.
156" Wheelbase.
COLOR = Blank.*
F653 = F600 4WD (gas) .. 18,000 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
P = Warner T-19 4 Speed Synchronized Manual Transmission.
62 = Rockwell model F106 Single Speed Rear Axle / 6.20-1 / 15,000 lbs. Rear Axle Capacity.
18,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
731284:
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
1284 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, the truck was painted a non standard color per the original purchasers order, making it a Domestic Special Order.
Old Jun 26, 2016 | 10:46 AM
  #456
C600's Avatar
C600
Bill, I've looked thru several sites and haven't found what I'm looking for, it may be a little hard but I'm wondering if there is a nos bumper left for a 56 C 600, part # THAB 17750-A, I've got two used ones but they are not fit to crome, they could be straightned and painted but too messed up to crome,would you have any ideas.
Thanks Aaron
Old Jun 26, 2016 | 10:52 AM
  #457
NumberDummy
Originally Posted by C600
Bill, I've looked thru several sites and haven't found what I'm looking for, it may be a little hard but I'm wondering if there is a nos bumper left for a 56 C600, part # THAB 17750-A I've got two used ones but they are not fit to chrome, they could be straightned and painted but too messed up to chrome, would you have any ideas.
Thanks Aaron
THAB-17750-A .. Painted Front Bumper = 1953/56 C500/600 / Obsolete
No Ford dealer or obsolete parts vendor has any.
Where in CA are you located?
Old Jun 27, 2016 | 12:09 AM
  #458
C600's Avatar
C600
Just south of Morro Bay on Hwy 1 about 3 miles.
Thanks,I'll see if Valley Crome can straighten it and then crome it.
I'm also looking for the stainless drip rail and my parts book doesn't show that number,this truck is a custom cab and that would finish it off nicely
Old Jun 27, 2016 | 11:22 AM
  #459
NumberDummy
The truck dismantlers yard that may have the bumper is in Los Angeles, too far for someone that lives where you do.
1953/55 Conventional Cab & Panel Truck Custom Cabs:
BAAA-8151700-A .. Right Drip Rail Moulding / Obsolete
BAAA-8151701-A .. Left Drip Rail Moulding / Obsolete
BAAA-8151718-A .. Front Drip Rail Moulding / Obsolete
Parts catalog does not differentiate between a COE and other trucks for these mouldings.
Old Jun 30, 2016 | 12:43 PM
  #460
hawkdog's Avatar
hawkdog
Dumpy
Thanks for the help on the last one, here's another!
SER - F6OU7R-16352
WEIGHT - 1700
WB - 172
HP - 149 @ 3600
TRANS - 5 MD DD
REAR - 6.3 8.81HD
CLR - F RED
PROD - 4C740347
DJHAWK
Old Jul 2, 2016 | 09:59 AM
  #461
C600's Avatar
C600
Thanks Bill, I was out of town all week and just got back.
I was hoping the drip rail might be around yet,I'll check a couple after mkt places and see if they have it,Sac Vintage Ford had it at one time but no longer, apparently their supplier quit making these.
Old Jul 2, 2016 | 10:15 AM
  #462
NumberDummy
SER - F60U7R16352
WEIGHT - 17000
WB - 172
HP - 149 @ 3600
TRANS - 5 MD DD
REAR - 6.3 8.81HD
CLR - F RED
PROD - 4C740347
Please list the info in sequence as stamped on the Rating Plate. The above is a mess...as it's all mixed up.
Old Jul 2, 2016 | 09:39 PM
  #463
hawkdog's Avatar
hawkdog
This might work better... if it works.
Her name is Dumpy... 'cause she has a dump bed.
Thanks
Old Jul 2, 2016 | 11:52 PM
  #464
85e150's Avatar
85e150
Does that VIN match the title? That there tag has been reattached. The factory used rivets, not Phillips head screws. That could be a good sign though. Many times a new door is installed with the plate from the donor truck left in place. In this case, maybe the OEM plate was transferred to a new door.
Stand by for more!
Old Jul 3, 2016 | 10:05 PM
  #465
hawkdog's Avatar
hawkdog
Stand by for more!
Good eye! I never thought twice about it.... Yes the title has the same VIN, but there could be some shady stuff goin' on here.
Standing.
