OLD DECODES
C70 = C700 Tilt Cab.
N = 302 4V
U = Louisville KY Assembly Plant.
160723 = 1961, assembled April 1961.
135" Wheelbase.
J = Rangoon Red.
C700 .. 22,000 lbs. GVWR
DATE: Omitted, there may not be one.
TRANS: Omitted.
AXLE: Omitted.
22,000 lbs. Gross Vehicle Weight Rating.
163 net HP @ 3600 RPM
DSO: Omitted, there may not be a DSO if the truck was not a special order.
A 1990 F-800
1FDXK84A4LVA44287
Axle Code 29P
Thank you !
1FDXK84A4LVA44287 / Axle Code 29P
X = Air Brakes - Class 7 - 26,0001-33,000 lbs. Gross Vehicle Weight Rating.
K84 = F800 Diesel.
A = 7.8L FTO Ford 6 Cylinder Diesel.
4 = Check Digit, FoMoCo use only.
L = 1990.
V = Kentucky Truck Assembly Plant.
A44287 = 1990 Numerical Sequence of Assembly, the trucks specific serial number.
AXLE 29P:
29 = Rockwell model RS-21-145 Single Speed Rear Axle / 4.30-1 / 21,000 lbs. Rear Axle Capacity.
P = Rockwell model FF-903 12,000 lbs. Capacity Front Axle with Power Steering.
VIN D61EU450634
WB 153
Color J
Model D612
Body 91A
Trans K
Axle G3
GVW 23000
99HP@2500RPM
DSO appears to be 74
Thanks!
E = Dagenham 330 I-6 Diesel.
450634 = 1964, assembled September 1963.
153" Wheelbase.
J = Rangoon Red.
D612 = C600 Diesel, 23,000 lbs. GVWR / 6,000 lbs. capacity front axle with hydraulic brakes.
91A = Tilt Cab.
K = Clark model 251VO 5 Speed Overdrive.
G3 = Eaton model 16802 Two Speed Rear Axle / 6.50/9.04 / 17,000 lbs. rear axle capacity.
23,000 lbs. Gross Vehicle Weight Rating.
99 net HP @ 2,500 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
VIN 1FDXK84E9DYA39109
Type- K84327
Body- 8
Trans- AB
Axle- Y6
Dist- 58
DSO- 1917
Thanks in advance for any info you can give me.
Vin- 1FDXK84E9PYA39109
WB- 154
Paint- ZA - it's white
Type- K84327 - I'm guessing K84 as in the vin and 327 for it's 32700lb GVW
Body- 8 - That's all that's on the tag, it a F800 single axle semi tractor with standard hood (non tilt forward front end)
Trans- AB - Allision MT643 on the trans tag
Axle- Y6 or V6 is all - it's a Rockwell but ? the ratio
Dist/DSO- 581917 - the white tag has the numbers split but the aluminum tag has them as one number
GVW- 32700lbs
It has a 8.3 12 valve Cummins and was a former government truck probably from a military base but not sure where.
Vin- 1FDXK84E9PVA39109
WB- 154
Type- K843 (27
) - I'm guessing K84 as in the vin and 327 for it's 32700lb GVWBody- 8 - That's all that's on the tag, it a F800 single axle semi tractor with standard hood (non tilt forward front end)
Axle- V6 is all - it's a Rockwell but ? the ratio
GVW- 32700lbs
X = Class 7 - Air Brakes - 26,000-33,000 lbs. Gross Vehicle Weight Rating.
K84 = F800 Diesel.
E = Cummins model FD-1460 8.3L (504 cid) I-6 Diesel.
9 = Check digit, FoMoCo use only.
P = 1994.
A39109 = 1994 Numerical Sequence of Assembly, the trucks specific serial number.
154" Wheelbase.
ZA = Diamond White.
K843 = F800 Diesel .. 25,500 lbs. GVWR
AB = Allison model MT643 Automatic Transmission.
V6 = Rockwell model RS-23-160 Single Speed Rear Axle / 4.10-1 / 23,000 lbs. Rear Axle Capacity.
581917:
58 = Twin Cities MN District Sales Office, where the original selling dealer ordered the truck from.
1917 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
Note: If sold to the US Government, the first two digits of the DSO: 83.
K84 = F800 Diesel.
L = 1990.
AXLE 29P:
>> Truck was sold as having the 6.6L Brazilian diesel- Bonus that is has the 210 H.P. / 600 ft lbs 7.8L !
<<Air Brakes, 46k miles, feeling GOOD !
Thanks for your service, NumberDummy !
