Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Feb 28, 2016 | 06:24 AM
  #391
VF1000R's Avatar
VF1000R
Finish dinner yet
Old Mar 9, 2016 | 08:07 PM
  #392
usmcpat's Avatar
usmcpat
Hello sir, I was wondering if I could have a moment of your time to help me decoad my vin on my 1987 f800? I'm really interested in what ring and pinion I have and any other information would be appreciated. The vin is 1FDXT84A5HVA24828. Again thanks for your time.
Old Mar 10, 2016 | 03:31 PM
  #393
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by usmcpat
Hello sir, I was wondering if I could have a moment of your time to help me decode my VIN on my 1987 F800?
I'm really interested in what ring and pinion I have and any other information would be appreciated. VIN: 1FDXT84A5HVA24828
AXLE code not within the VIN (as you can see), it's printed by itself on the Certification Label.
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
X = Class 7 Air Brakes, 26,001-33,000 lbs. Gross Vehicle Weight Rating range.
T84 = F800 (gas).
A = 7.8L (476 cid) V8 (gas).
5 = Check digit, FoMoCo use only.
H = 1987.
V = Kentucky Truck Assembly Plant.
A24828 = 1987 Numerical Sequence of Assembly, the trucks specific serial number.
Old Mar 10, 2016 | 04:44 PM
  #394
Destroked 450's Avatar
Destroked 450
NumberDummy when you have time could you decode my 93 F-800
VIN 1FDXK84E9DYA39109
Type K84327
Body 8
Trans AB
Axle Y6
Dist 58
DSO 1917
Thanks in advance.
Old Mar 15, 2016 | 08:41 PM
  #395
josh6431's Avatar
josh6431
Would like my vin decoded please, also need all the brake lines and associated parts from the rear frame rail up to the wheel cylinders.
vin. 1FDPK74N2EVA15872
thanks for your help
Old Mar 16, 2016 | 01:40 PM
  #396
NumberDummy
Originally Posted by josh6431
Would like my vin decoded please.
1FDPK74N2EVA15872
P = Class 7, Hydraulic Brakes - 26,001-33,000 lbs. Gross Vehicle Weight Rating range.
K74 = F700 Diesel.
N = Detroit 8.2L 8 cylinder Diesel.
2 = Check digit, FoMoCo use only.
E = 1984.
A15872 = 1984 Numerical Sequence of Assembly.
Old Mar 16, 2016 | 04:56 PM
  #397
josh6431's Avatar
josh6431
[QUOTE]Quote:
1FDPK74N2EVA15872
K74 = F700 Diesel.
E = 1984.
A15872 = 1984 Numerical Sequence of Assembly./QUOTE]
Thanks for the info, any idea on the parts? The main part number I need is for the rear brake connector/ ditribution tee.
Old Mar 16, 2016 | 06:51 PM
  #398
fordc600's Avatar
fordc600
C600 numbers please!
Hi Number Dummy,
Thanks for helping us all out with our data tag info!
It's greatly appreciated. You have helped me a few times. After many fortunes won and lost, and vehicles come and gone, I'm getting a c600 Friday. Owner says it's a 67, but after looking at another vin you decoded, I'm not sure.
Vin is C61DUA74064
Thanks I appreciate it!
Old Mar 17, 2016 | 02:21 PM
  #399
NumberDummy
Originally Posted by fordc600
Hi Number Dummy,
Vin is C61DUA74064
I'm not sure either as this VIN could decode to either a 1967 or a 1976.
C61 = C600 Tilt Cab.
D = 330 2V Heavy Duty FT engine.
U = Louisville KY Assembly Plant.
A74064 = 1967, assembled in January 1967 or 1976.
Kentucky Truck Assembly Plant (Assembly Plant code V) opened in 1969, where C Series were assembled from then on.
1968 was the first year that the door emblems have yellow reflectors made as part of them. No yellow reflectors, it's a 1967 or earlier.
Old Mar 17, 2016 | 03:38 PM
  #400
fordc600's Avatar
fordc600
Thank you Sir!
No reflector on door badge. It has the older trapezoid shape emblem the the FORD letters above it, so must be '67.
Also, the guy I bought it from thought it was a 390, so that was another fact you corrected.
Thanks again!
Old Mar 19, 2016 | 11:39 AM
  #401
thomas1's Avatar
thomas1
Any info is appreciated. Thanks.
Old May 1, 2016 | 09:54 AM
  #402
fullbore1's Avatar
fullbore1
1968 f800 with marmon herrington conversion
I am looking for any information regarding the hydraulic front drum brake hardware kit. It has 16x2.25" shoes. Any help will be geatly appreciated. Thank you
Old May 2, 2016 | 08:33 PM
  #403
NumberDummy
There's nothing that I can do since you have a Marmon-Herrington conversion.
Old May 5, 2016 | 08:48 PM
  #404
NoFrod's Avatar
NoFrod
Former City of Denver Hot Asphalt (Tar) Applicator
I've got one for you:
A 1990 F-800
1FDXK84A4LVA44287
Axle Code 29P
Thank you !
Old May 8, 2016 | 07:20 PM
  #405
CF700's Avatar
CF700
I have a 1961 CF700 which appears to be original, what can you tell me about thevin #?
C70NU160723
W.B. COLOR MODEL DATE TRANS 135 J C700 - J F2
Many thanks
