Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Apr 19, 2015 | 05:57 AM
  #286
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TWO different switches: D0TZ-13341-A (ID number: D3TA-13B302-CA) & D1HZ-13341-A (ID number: D0HA-13B302-B or C or D2HA-13B302-AA)
Which type does your truck have? T/T refers to Tractor-Trailer.
A paper tag looped over the wires has the ID number on it.
Both are obsolete, but are available NOS
Old Apr 19, 2015 | 11:42 AM
  #287
Waysize's Avatar
Waysize
Thanks for the information NumberDummy. Now I know its a 73 not a 74. Now I gotta get this darn Holley tuned.
Old Apr 20, 2015 | 01:50 PM
  #288
harvf16's Avatar
harvf16
Question New to Me 1985 F600 Vin info?
Bill can you help me decifer this vin?
1FDMF60HXFVA48086
F60F * FPM NA
Thanks
Old Apr 24, 2015 | 05:58 PM
  #289
NumberDummy
1FDMF60HXFVA48086
1FD = FoMoCo USA - Truck - Incomplete Vehicle.
M = Class 5 Hydraulic Brakes - 16,001-19,500 lbs. Gross Vehicle Weight Rating.
F60 = F600 2WD (gas).
H = 370 2V or 4V (6.1L).
X = Check digit, FoMoCo usage only.
F = 1985.
V = Kentucky Truck Assembly Plant.
A48086 = 1985 Numerical Sequence of Assembly, the trucks specific serial number.
Old May 2, 2015 | 07:17 PM
  #290
cornwelltoolman's Avatar
cornwelltoolman
Bill
I am looking for a few parts for my 86 c700
maybe with your sources you can help
i need 2 B7T 9121452-A
2 B7T 921453-A
and 2 D0HZ 8021508-a
Old May 3, 2015 | 05:58 AM
  #291
NumberDummy
Originally Posted by cornwelltoolman
Bill, I am looking for a few parts for my 86 C700. Maybe with your sources you can help.
I need (2) B7T-9121452-A / (2) B7T-9121453-A / (2) D0HZ-8021508-A
1957/86 C/CT500/900:
2) B7T-9121452-A .. Weatherstrip at Belt-Right Outer & Left Inner / Obsolete
No Ford dealer or obsolete parts vendor has any.
2) B7T-9121453-A .. Weatherstrip at Belt-Left Outer & Right Inner / Obsolete
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
Belt weatherstrips aka anti-rattlers are called "cat whiskers" by auto glass shops.
Check with local auto glass shops, they sell the cat whiskers and the clips by themselves. Cat whiskers come in a 5' or so length and are "cut to fit."
1967/72 F100/750 / 1970/89 L/LN/LNT/LT/LTS500/900 / 1980/86 C/CT600/900:
2) D0HZ-8021508-A (replaced C7TZ-8121508-A) .. Run-Front Door Glass-Latch Side - 67" long / Obsolete
Since most partsguys pronounce the zero (0) as the letter O, the D0HZ prefix can also be typed as DOHZ, which most of the following are listed under.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746 (D0HZ).
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965 (DOHZ).
GOODE MOTOR INC. in Burley ID has 8 = 800-535-7278 (DOHZ).
CROSSROADS FORD TRUCK SALES in Springfield IL has 50 = 800-593-3673 (DOHZ).
Pic from 1980/89 600/900 Truck Parts Catalog, available on a C/D from hipoparts.com
Old May 3, 2015 | 04:49 PM
  #292
cornwelltoolman
Thanks Bill
Old May 20, 2015 | 03:09 PM
  #293
mlageson's Avatar
mlageson
Hi All. Just bought a 1976 C800 Altec bucket truck. The vin sticker on the door pillar is 90% gone. I need a VIN number to get a title. Where would I find the VIN stamped on the frame? I looked on the top of both frame rails. The ultility body covers the frame rails behind the front spring rear shackles. Any thoughts? There are numbers stamped on the side of the right frame rail
71 1036 51
EZHT NLA
351
Any thoughts?
Old May 21, 2015 | 02:18 AM
  #294
NumberDummy
Originally Posted by mlageson
Hi All. Just bought a 1976 C800 Altec bucket truck. The Safety Standard Certification Label on the door (B) pillar is 90% gone.
The numbers you posted that are stamped on the (probably right outer) frame rail have nothing to do with the VIN
I don't know where the hidden frame VIN is stamped, but the VIN can be found on the following:
Warranty Plate riveted to the left door face below the latch. May have been painted over.
Safety Standard Certification Label glued to the B Pillar below the striker plate.
Composed of a clear outer layer and inner layer with printed info, when it got wet, the outer layer could peel off, taking some/all of the inner layer along with it.
Only the VIN, production date and misc. GVWR's are printed on this label.
Truck is registered by its specific VIN which is composed of 11 digits (thru 1980).
Replacement Certification Label & Warranty Plate with all the original codes stamped on it, is available from martiauto.com by passing along your VIN and some bucks.
Old May 23, 2015 | 03:27 PM
  #295
jrk3332's Avatar
jrk3332
Bill can you give me the part #'s for the pieces making up the horn assembly on steering column of a 1974 F600. I started a new thread asking this same question before I saw this thread so I apologize for posting the same question in 2 different places. Thanks in advance for your help.
Old May 24, 2015 | 12:43 PM
  #296
NumberDummy
See the thread you started.
Old May 25, 2015 | 10:30 PM
  #297
cornwelltoolman
Bill
I am looking for king pins for my 86 c700 it has a 9000 lb axel with hydraulic brakes I can only find them for a 9000 lb axel with air brakes
axel code is FSN in case I de coded it wrong
Old May 26, 2015 | 12:41 PM
  #298
NumberDummy
I am looking for king pins for my 86 C700, it has a 9000 lb. axle with hydraulic brakes.
I can only find them for a 9000 lb axle with air brakes. AXLE code: FSN in case I decoded it wrong.
FS = Eaton model 17101 Single Speed Rear Axle / 5.29-1 / 19,000 lbs. Rear Axle Capacity.
N = 9,000 lbs. Capacity Ford Front Axle with P/S
C/CT700's with 9,000 lbs. capacity with hydraulic brakes only listed for 1980/83's.
Are you sure it's a 1986? Are you sure it's a C700? It might be a CF700 and if so...
Post the VIN to verify.
Old May 26, 2015 | 10:05 PM
  #299
cornwelltoolman
1FDPD74N76VA14889
Old May 27, 2015 | 03:14 AM
  #300
NumberDummy
1FDPD74N76VA14889
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
P = Class 7 Hydraulic Brakes - 26,001-33,000 lbs. Gross Vehicle Weight Rating.
D74 = 1981/86 C700 Diesel (non sleeper).
N = Detroit DD 990N or DD 990T 8.2L (501 cid) V8 Diesel.
7 = Check digit, FoMoCo use only.
6 = 2006 it's probably G = 1986.
A14889 = 1986 Numerical Sequence of Assembly, the trucks specific serial number.
It's what you said it is: 1986 C700 with hydraulic brakes and a 9M front axle. Are you LDS?
See application chart below. The 1980/89 Heavy Truck Parts Catalog (10/93 edition) is probably wrong, so you need to find another source with better info.
Call Larry H. Miller Ford (SLC) for assistance, or Green Sales Co. (Cincinnati OH - 800-543-4959), or Job Lot Auto (joblotauto.com - Queens NY), who specializes in BIG Ford truck parts.
