Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Feb 22, 2018 | 03:37 PM
  #766
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The problem with the pic is, it doesn't appear when the post is quoted, so I had to type the info.
Warranty Number: U90TVL96524 / WB: 174 / COLOR: A / MODEL: U907 / BODY: AE8 / TRANS: J / AXLE: CVP / MAX GVW LBS: 56000 / CERT NET HP: 236 / RPM: 1750 / DSO: 11
U90 = LT900 (diesel) .. (LT9000 is an LT900 w/a diesel engine).
T = Detroit model 8V-71N 568 cid 8 Cylinder Diesel.
V = Kentucky Truck Assembly Plant.
L96524 = 1971.
174" Wheelbase.
A = Raven Black.
U907 = LT900 (diesel), 56,000 lbs. GVWR
AE8: AE = Medium Gray Vinyl / 8 = Standard Cab.
J = Fuller model RTO-9513 13 Speed Overdrive.
CVP:
CV = Eaton model 42DP Forward Rear Axle; 5.05-1; 44,000 lbs. Axle Capacity / Eaton model 42RP Rear Rear Axle.
P = Rockwell/Timken model FF903 12,000 lbs. Capacity Front Axle with Power Steering.
56,000 lbs. Gross Vehicle Weight Rating.
236 net HP @ 1,750 RPM
11 = Boston MA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Feb 22, 2018 | 05:18 PM
  #767
Dano L9000s's Avatar
Dano L9000s
Thank you for the decoding info. Is there a different way I should attach a photo to the post so it will show when quoted and you don't have to retype the tag info? The way I did it was advanced reply and typed in the text and then attached the tag photo under the "Attach Files - Manage Attachments" Option. Thanks, Dano
Old Feb 23, 2018 | 12:38 AM
  #768
NumberDummy
Hell, I haven't a single clue. I've posted a few pics on FTE, I just do it like I post parts catalog pics.
Old Mar 10, 2018 | 06:43 PM
  #769
DBrawley's Avatar
DBrawley
1957 F600 headlight switch
Hi, Bill! Could you look up the part number for the headlight switch for my 1957 (yes, I double checked to make sure I got the year correct this time)! F600?
Thanks, as always for all that you do for us!
Dave
Old Mar 11, 2018 | 01:36 AM
  #770
NumberDummy
Dave
B7A-11654-A .. Headlamp Switch (Motorcraft SW-294) / Obsolete
1957 F100/900 & C550/900; 1957 Ford/Thunderbird Passenger Cars.
MUSTANG'S ETC in Van Nuys CA has 1 = 818-787-7634.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
MCDONALD OBSOLETE PARTS in Rockport IN has 4 = 812-359-4965.
Old Mar 11, 2018 | 08:53 PM
  #771
DBrawley's Avatar
DBrawley
Awesome! Thanks, Bill!
Old Mar 12, 2018 | 05:53 PM
  #772
Kenneth's68's Avatar
Kenneth's68
I'm looking at a 1998 F700, I haven't seen the truck in person yet, it blows coolant out the radiator. I would like to find out what engine it has before making the drive out to look at, the vin is 1FDNF70J7WVA07220, trans AE, axle TE
Thanks
Old Mar 12, 2018 | 07:33 PM
  #773
BeFord's Avatar
BeFord
69 f700 vin decode
I need to replace carrier bearing abd u joints in this truck, and they asked me 300 questions about the rear axle. Only thing I could say was it's under the truck... at the rear.. Thank you for your time.
Old Mar 12, 2018 | 07:55 PM
  #774
NumberDummy
I'll just decode the AXLE for now, the rest of it either later tonight or tomorrow....and will edit the info into this post.
E3A:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
A = Ford 5,000 lbs, Capacity Front Axle.
Old Mar 13, 2018 | 12:09 PM
  #775
BeFord's Avatar
BeFord
E3A:
thank you.Parts house says they don't list that axle. Needing carrier bearing for drive shaft. Guess. We will try th matching game.
Would you be able to find the part number for the wiring harness that catches the head lamps and marker lights on the drivers side? Longshot I know, but would like the nos if available. Fire damaged existing. Thanks again for your assistance.
Old Mar 13, 2018 | 01:12 PM
  #776
Rushman1966's Avatar
Rushman1966
Hi. New member here. Could somebody please decode this entire VIN and I would be very grateful. I can gather it is a C800 tilt cab made in Louisville, Kentucky with (I believe) a 361 2V FT Engine. However the rest regarding trim color, axles, tranmission, gross weights and the build date are beyond my googling capabilities. Thank you in advance.
Old Mar 14, 2018 | 05:20 PM
  #777
Corn73's Avatar
Corn73
Vin info
Hey Number dummy, I'm new to here so hope im posting this right.
I can tell by your postings you're busy, but could you please decifer this Vin tag? The fender badges show it to be an N1000 . The pic is hard to read but I believe the numbers are
N80CU971518
2L2 J M805 E0818N DNH
49000 208 2800 320845
Thanks in advance.
Old Mar 14, 2018 | 09:05 PM
  #778
NumberDummy
Originally Posted by Corn73
Hey NumberDummy, I'm new to here so hope i'm posting this right.
I can tell by your postings you're busy, but could you please decipher this Warranty Plate? The fender badges show it to be an N1000.
The pic is hard to read but I believe the numbers are: N80CU971518
N80 = LN800 (gas). No gas engine has 208 net HP @ 2,800 RPM / C = 330 2V M/D FT engine (approx. 164 net HP @ 3,800 RPM) / U = Louisville KY Assembly Plant / The 9 is wrong, has to be a letter.
2nd line: WB in inches: 2L2 / COLOR: J / MODEL: M805 / BODY: E0818N / TRANS: / AXLE: DNH
3rd line: MAX GVW LBS: 49000 / CERT NET HP: 208 / RPM: 2800 / DSO: 320845
Look at the Warranty Plate again, because the VIN and 2nd line you typed are mass confusion. 3rd line: The net HP @ RPM do not match the 330 FT engine.
What year is this truck? Could you post a pic of this plate?
Compare the VIN on the title/registration to the VIN on this Warranty Plate to see if they match.
Old Mar 14, 2018 | 11:41 PM
  #779
94strong's Avatar
94strong
High mount brake light
I have a 94 f150 and I’m missing the 3rd brake light. Didn’t realize it was missing until I removed the shell that was on the bed when I bought the truck. Now I have a hole in the cab of the truck which may explain the slight leak I have. Could you find the part number for the 3rd brake light please and if you could find out if anyone has one I’d appreciate it.
Old Mar 15, 2018 | 12:13 AM
  #780
NumberDummy
You are asking this question in the wrong forum, this forum is for 500 and larger series trucks.
Please ask questions in the 1987/96 F150 and larger F series forum.
