I have a 1962 f 500. Hard to find info on this so far.
Vin- f50JK230035
for axle it says 32
trans - F
i know it originally had a 6 cylinder, it it now has a 8 cylinder. I want to pull motor and tranny and put new seals in, they both operate fine, just leak.
I have a 1962 F500. Hard to find info on this so far.
VIN: F50JK230035 / TRANS: F / AXLE: 32
I know it originally had a 6 cylinder, it it now has a 8 cylinder. I want to pull motor and tranny and put new seals in, they both operate fine, just leak.
F50 = F500.
J = 223 1V I-6.
K = Kansas City MO Assembly Plant.
230035 = 1962, assembled November 1961.
F = Borg-Warner T-98 4 Speed Manual Transmission.
32 = Timken model C100 Single Speed Rear Axle / 6.20-1 / 11,000 lbs. Axle Capacity.
The swapped engine may be a 292 Y block, as it was an option in these trucks. The distributor is behind the carburetor.
Hey Number Dummy! I've got another truck to decode if you would. Has 4x4 conversion.has Napco emblems on the cowl. I can't get the pics to upload for some reason.
Vin N61EUE73393
WB 181
COLOR U
MODEL N611
BODY 4281
TRANS M
AXLE 53A
22000 GVW
CERT UP 182 AT 3800
DSO 74
