Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Dec 9, 2017 | 06:29 PM
  #661
Notmeofficer's Avatar
Notmeofficer
Ok.. and now for NEW..not NOS that's been sitting around forever rubber.. here we go
F600 300 six and a bunch of others.. this is my best guess without actually having one in my hand.. but Im going to order some
Searching for C1TT-6A061-C .. Lower Insulator this popped up
https://www.steelerubber.com/motor-mount-20-0597-11
and the upper
C3TZ-6068-D .. Upper Insulator
https://www.steelerubber.com/motor-mount-20-0598-11
They list an OEM number as : C3TZ-6068-D. but it looks the same to me without having it in my hand
Useage: 1961-64: 6 cyl. 223 & 262 F500-600 series, 8 cyl. 292 F350-700 series before Serial #140,001, 6 cyl. 223 F100-250 series 4x2s; 6 cyl. 223 F100-250 series 4x4s; 6 cyl. 223 F350-600 series from Serial #140,001; 6 cyl. 262 F600 series; 8 cyl. 292 F100-250 series 4x2s; 8 cyl. 292 F100-250 series 4x4s
1963-64: 6 cyl. 223 & 262 F100-250 series 4x4s; 6 cyl. 223 & 262 F350 series.
I also suggest Anchor industries.. they have an online search catalog.. Im still working on a possible Anchor number.. because anchor is available everywhere
In researching Anchor there is a possibility the part numbers are 2048 and 2050.. but this is by picture only and for an earlier year light duty six truck.. Im going to order some of those through my oriellys and see.. I didnt find a listing for the F600 300 six truck.. just the v8's
Old Dec 9, 2017 | 06:30 PM
  #662
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic from 1980/89 catalog: Specs for E5TZ-18599-C (notice the 3/4" heater hose connection):
I found another in the 1973/79 (Light Truck) catalog that is similar, but has a 5/8" heater hose connection (D9TZ-18599-A).
Old Dec 9, 2017 | 06:36 PM
  #663
Notmeofficer
Specs for E5TZ-18599-C =
You are right Bill..I missed the 5/8 vs 3/4. specs ... now I get to buy that one too.. but I doubt Ill need another one in the trucks life.. the first one has lasted nearly forty years and Ill be long rusted by then
In researching the above number there was info it was superseded by E2TZ-18599-A.. who knows if that is correct
Still trying to confirm fitment of an ANCHOR number for the motor mounts for 300s... by PICTURE only the ones I found (above) look like the right ones... but they were for much earlier light duty six trucks
Old Dec 9, 2017 | 06:39 PM
  #664
NumberDummy
Originally Posted by Notmeofficer
That's the one Bill.. specs match what I have in my hand... yippee Ford.. still making them after all these years..unfortunately no aftermarket so it was dealer ..ouch
E5TZ-18599-C = MSRP: $48.10 / autonationfordwhitebearlake.com online price: $26.46
Auto Nation Ford ~ White Bear Lake MN .. Best price on the net, dealer cost +10%
Old Dec 9, 2017 | 07:02 PM
  #665
Notmeofficer
I ordered both of them.. I have no time to waste... I know one of them will be correct..I only have to do it once and its the only piece that's iffy in the whole system.. in the big picture,.,,no problem
Old Dec 9, 2017 | 07:24 PM
  #666
Notmeofficer
Bill.. last question for the weekend
You wouldn't have a diagram for the smog lines for a 1979 F600 300 six California version motor?
The vacuum line diagram sticker is no longer readable.. the other emission sticker is
D9TE-9C485-AMB
I would love to find the stickers.. fat chance... I tried my mojo and no luck
Old Dec 10, 2017 | 10:54 AM
  #667
NumberDummy
Evaporative Emission system:
Old Dec 10, 2017 | 08:22 PM
  #668
Notmeofficer
[QUOTE=NumberDummy;17647041]Evaporative Emission system:
Thank you Bill..just what I needed
Cam
Old Dec 11, 2017 | 04:14 PM
  #669
300cidguy's Avatar
300cidguy
NumberDummy-
Any chance I could get you to decode this VIN tag? What this lay person cannot figure out is in red.
Warranty Number- F61MK702507
W.B.- 174
Color- J
Model- F612
Body- 481
Trans- L
Axle- 73C
Max. G.V.W. LBS.- 23000
Cert. Net H.P.- 160
R.P.M.- 3800
D.S.O.- 521197
Thank you in advance!
Old Dec 12, 2017 | 09:29 AM
  #670
NumberDummy
Originally Posted by 300cidguy
Warranty Number: F61MK702507 / WB: 174 / Color: J / Model: F612 / Body: 481 / Trans: L / Axle: 73C / MAX GVW LBS: 23000 / Cert Net HP: 160 / RPM: 3800 / DSO: 521197
F61 = F600 (gas).
M = 330 2V H/D FT engine.
K = Kansas City MO Assembly Plant.
702507 = 1965.
174" Wheelbase.
J = Rangoon Red
F612 = F600 (gas); 23,000 lbs. GVWR
481: 4 = Light Beige Crush Vinyl & Light Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
L = Clark model 2651-V1 or 2351-V1 5 Speed Direct.
73C:
73 = Eaton model 1614 or 1615 Single Speed Rear Axle / 6.50-1 / 17,000 lbs. Rear Axle Capacity.
C = Ford Rockwell-Timken 6,000 lbs. Capacity Front Axle.
23,000 lbs. Gross Vehicle Weight Rating.
160 net HP @ 3,800 RPM
521197:
52 = Des Moines IA Ford District Sales Office, where the original selling dealer ordered the truck from.
1197 = Domestic Special Order number, truck ordered spoecial by the original purchaser, not "bought off the lot."
Old Dec 12, 2017 | 10:30 PM
  #671
DBrawley's Avatar
DBrawley
1957 F600 brake booster check valve
Hi ya, Bill! My truck is really coming along! I've got it running nicely, driving well and it's even licensed and insured! So, what I'm working on now is a check valve that goes in between the intake manifold and the power brake booster. The part number for a 1956 F600 could be 7RT-2365-B. I got that number from an ad on eBay so please take it with the usual grain of salt. I am only including it here to (hopefully) help you in the search for the correct part for mine...
As always, thanks for all that you do for us around here!
Old Dec 13, 2017 | 11:00 AM
  #672
NumberDummy
The part number for a 1956 F600 is 7RT-2365-B
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
Old Dec 13, 2017 | 03:50 PM
  #673
DBrawley's Avatar
DBrawley
Great! Thanks, Bill! So, that number is correct and applicable to a 1957 as well as a 1956, right?
Old Dec 14, 2017 | 01:18 PM
  #674
NumberDummy
7RT-2365-B .. Brake Booster Vacuum Check Valve / Obsolete
1957/60 applications: 1957/59 F250/600 // 1957/60 F700/950.
Misc (not all of them) 1948/56 applications: 1948/52 F4/F5/F6 & F5/F6 COE // 1953/56 F500/600 & C500/600 // 1954/56 F250/350.
Old Dec 14, 2017 | 05:37 PM
  #675
DBrawley's Avatar
DBrawley
Awesome! Thank you, Bill!!
