Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old Jun 5, 2013 | 12:17 PM
  #46
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Thanks Bill for the speedy response.
I've actually been trying to get that part for many years... and I didn't care if it was off of an Excursion or whatever (I have quite a few Excursion parts on the truck as it is). So if that accumulator insulator were found in ANY model of Superduty from 1999-2001, I'd have bought it, because that would make a much easier starting point to improvise from. But obviously, one cannot order a part from Ford without a number, so I never was successful.
Thanks for trying though!
Old Jun 15, 2013 | 09:23 AM
  #47
Garmo's Avatar
Garmo
1981 C700
Bill, first - thank you for your good work on this forum. I am sure I am not alone in being appreciative to have such a great resource as you.
Please decode my vin and also I am looking for all new window rubber for my 81 C700
Vin per my ins card is 1FDPC70K0BVJ22128 - confirmed in door jamb.
Type is C708 Body is BS8 trans is JCC axle is HHN
Do you know if there is an electric fuel pump for this engine? I am starting to see vapor lock. Finally, I need a dip stick tube as well.
Thanks for your assistance.
Gary
Old Jun 16, 2013 | 03:06 AM
  #48
bradinwnc's Avatar
bradinwnc
1976 F700 Help
Hey Bill,
I've got a 76' F700 with a 5 speed and two speed axle. The truck has a dump bed and pto mounted on the right side. I installed a second PTO on the left side for a knuckle boom I had on another truck but the PTO speed is WAY slower so I am researching options for a new PTO, PTO gears, etc.. What a let down when the dang thing would hardly move the outriggers.
Anyway, I have no idea what transmission, engine, etc is in the truck and would appreciate any info I can get about the truck, transmission, axle, etc, or thoughts about upping the speed on the PTO or maybe another pump mounting option?
The VIN is F70EVC35776
type is F705
body is 418
Transmission code is M
Axle code is E2M
Thanks in advance.
I googled for hours with no luck on getting info.
Old Jun 16, 2013 | 05:03 AM
  #49
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bradinwnc
Hey Bill,
I've got a '76 F700 with a 5 speed and two speed axle. The truck has a dump bed and pto mounted on the right side. I installed a second PTO on the left side for a knuckle boom I had on another truck but the PTO speed is WAY slower so I am researching options for a new PTO, PTO gears, etc.. What a let down when the dang thing would hardly move the outriggers.
I have no idea what transmission, engine, etc is in the truck and would appreciate any info I can get about the truck, transmission, axle, etc.
VIN: F70EVC35776 // TYPE/GVW: F705 / BODY: 418 / TRANS: M / AXLE: E2M
F70 = F700.
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
C35776 = 1976.
F705 = F700, 24,000 lbs. Gross Vehicle Weight Rating.
418: 41 = Black all Vinyl / 8 = 81A Standard Cab.
M = Clark model 285V 5 Speed Direct.
E2M: E2 = Eaton model 16244 Two Speed Rear Axle / 6.17/8.58 / 17,500 lbs. Rear Axle Capacity // M = Ford 7,000 lb. Capacity Front Axle with P/S.
Old Jun 16, 2013 | 07:30 AM
  #50
bradinwnc's Avatar
bradinwnc
F70 = F700.
C35776 = 1976.
Wow, thanks for the super quick response..its there anybody/where on the forum that would be a good resource to ask about my pto issue? I have the Chelsea pto model, cross pump model, and knuckle boom model, pressure, and flow requirements..I'm hoping someone can help me out as far as where to go from her, hopefully using the pump I've got and maybe at least the pto housing, maybe with new gears, or at least point me in the right direction..
Again, thanks for the help..
...where would I look for the tag be on the transmission and motor to verify that they are what was original?
Old Jun 18, 2013 | 04:37 AM
  #51
Tatum81's Avatar
Tatum81
Bill, I am a new member and just want to say you are amazing. People like you help make this hobby possible for so many enthusiasts. When I get around to uncovering the VIN plate on what I believe is a 1953 F600 I will definitely post it for a translation from you. Thank you so much
Old Jun 18, 2013 | 04:41 PM
  #52
babs.demo.const's Avatar
babs.demo.const
Bill,
I just recently purchased a 1962 C600 dump truck for use in my demolition and construction business, and would like to have some more info on my truck. The information on the plate in the glove compartment is as follows...
Serial #. C60BU281696
WB. 135
Color. C
Model. C600
Trans. F
Axle. E2
Max GVW. 19,500
Net HP. 132
RPM. 3600
D.S.O. 650477
Thanks in advance.
Bryce
P.S. I am looking for a water pump for this truck...all my local parts stores tell me they can't get one for it. Any help will be greatly appreciated
Old Jun 18, 2013 | 05:29 PM
  #53
NumberDummy
Originally Posted by babs.demo.const
Bill, I just recently purchased a 1962 C600 dump truck for use in my demolition and construction business, and would like to have some more info on my truck.
VIN: C60BU281696 / W.B. 135 / Color: C / Model: C600 / Trans: F / Axle: E2 / Max GVW: 19,500 / Net HP: 132 / RPM: 3600 / D.S.O. 650477
I am looking for a water pump for this truck (see below)...all my local parts stores tell me they can't get one for it. Any help will be greatly appreciated
Welcome to FTE
C60 = C600 Tilt Cab.
B = 262 1V I-6.
U = Louisville KY Assembly Plant.
281696 = 1962, assembled February 1962 / This is the trucks specific serial number.
135" Wheelbase.
C = White.
C600 Tilt Cab, 19,500 lbs. GVWR
F = Borg Warner T-98 4 Speed Manual Transmission.
E2 = Eaton model 13800 2 Speed Rear Axle / 6.33/8.81 / 14,000 lbs. Rear Axle Capacity.
19,500 lbs. Gross Vehicle Weight Rating.
132 net HP @ 3,600 RPM
650477:
65 = OKC Ford District Sales Office, where the original selling dealer ordered the truck from.
0477 = Domestic Special Order number, truck special ordered by original purchaser, not "bought off the lot."
C2TE-8501-A .. 1961/64 262 I-6 Water Pump / Obsolete
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959.
Old Jun 18, 2013 | 05:49 PM
  #54
babs.demo.const
Thanks a bunch...you are such a help to so many people...keep up the good work.
Bryce
Old Jun 18, 2013 | 10:30 PM
  #55
85e150's Avatar
85e150
This appears to be a series of pics of a 285:
Transmissions & Transmission Parts | Transmission Assys - Heavy Truck Part Details - 100.00 285 69919 Assys B/M: Clark Clark? Manfctr. Parts Transmission Transmissions Michigan ~|~ Assembl Assembly ***'y Complete MO16G10C TRANSMISSION Transmission/Tr
As for your PTO, I think they can change the gears in those, but you will have to find an outfit locally that works on them. I recently tried to search out PTO info in another thread and didn't find much. There are tons of different PTO models. IMO, you need to find an outfit that deals with them and take your unit to them. Make sure they can work on it and that the gear they change--if that's an option--works with your trans.
Old Jun 19, 2013 | 10:04 AM
  #56
Garmo's Avatar
Garmo
Any info you can supply is appreciated.
Gary
Old Jun 21, 2013 | 08:06 AM
  #57
DragonPen999's Avatar
DragonPen999
Hi Bill, I have an 84 F700 that I'm looking at for an axle swap for my 85. I need to know what the axle is and I can't find the axle tag.
VIN: 1FDPF70H3FVA02926
TYPE: F70A
BODY: GH8
TRANS: SL
AXLE: JHN
Would you know the gear ratio for that rear end and these Spicer transmissions?
CM-5852-A
CM-4054-D
Old Jun 21, 2013 | 10:50 PM
  #58
DragonPen999
Hey Gary, this is what I can tell you from my 85 service manual.
1FDPC70K0BVJ22128
1FD~Ford Motor Company
P~Hydraulic brakes class 6
C70-C700
K~7.0 429 gas engine
0~check digit
B~1981
V~Kentucky Truck
J22128~ Sequence Number
C708~ C700 28,000 GVWR
JCC~? Mine lists a CC trans as Clark 282VHD 5-Speed
HHN~HH Eaton 17221 7.17-9.77 N 9,000lb steel power stearing
As for the fuel pump mine was in the tank. Big monster, I still have it if you are near ohio.
Most parts are fairly easy to find, I just tell auto parts boys I have a F250 with a 460. Really only a few parts that won't work.
Hope this helps.
Old Jun 23, 2013 | 11:36 AM
  #59
Tatum81's Avatar
Tatum81
Bill, checking through this forum, I am not even sure I do have the VIN, but here goes. The plate inside the glovebox says FEE81AHQ-5235 14 87 4-STD 633/981
F600 154 16000 GVW lb
I believe it to be a 1953 F600' 4 spd tranny, 2spd rear axle. If there is anything more you can tell me I sure would appreciate it. There is also a plate on the firewall
Style CBAAA-81A
Body No 441
BCDQ-435
37
The next part is where you groan, and I know you can see it coming. yes it has the dubious and dangerous Budd wheels. Yes I bought it already. Does anyone know where a set of safe replacements? Feel free to add comments about knowing better.
Old Jun 23, 2013 | 03:42 PM
  #60
85e150's Avatar
85e150
What lug pattern do you have? 5 or 6 lugs?
