Build Progress (So Proud)
Old Jan 14, 2014 | 04:56 PM
  #256
snook715's Avatar
snook715
Anyone had any expeience with an AOD for a big block (429 or 460)? Its looking like the E40D is not going to happen for a reasonable amount of $$$$ and i wont go with a tail shaft over drive unit on my C6.
Old Jan 14, 2014 | 05:06 PM
  #257
UNTAMND's Avatar
UNTAMND
Originally Posted by snook715
Anyone had any expeience with an AOD for a big block (429 or 460)? Its looking like the E40D is not going to happen for a reasonable amount of $$$$ and i wont go with a tail shaft over drive unit.
If I were to not use an e4od I'd look into the 700r4 if you don't want electronics, or a 4l80 if you don't mind electronics.
You'll need an adaptor no matter what because aod was only behind sbf engines. And unless you get a lentech, you'll ruin it in no time behind a bbf.
For the money you'll spend getting something other than an e4od behind a 429/460, you could have had an e4od behind your 429/460... Know what I mean.
How much hp is your engine making. For 4-500 you can get the trans controller and I've put about 400hp into mine for years bone stock. Diesels are putting lots of torque into them. They don't have as many issues as you read about. They are great transmissions and require little upgrades for the normal person.
Old Jan 14, 2014 | 05:18 PM
  #258
drptop70ss's Avatar
drptop70ss
what rear gear are you running? May be easier to just use a C6 and a mid to low 3 series gear.
Old Jan 14, 2014 | 05:26 PM
  #259
snook715's Avatar
snook715
UNTAMND I'm so stretched thin on my budget Im' trying hard not to skimp now. I do understand what you mean but honestly I'd just like to drive my poor truck before I'm married. I just got finished reading about the Lentech AOD this afternoon. For the money they charge I'd rather try my had at the E40D and controller.
One question I do have is with an E40D do you need the stock computer and trans controller or just the controller? Oh ya and do all E40D transmissions bolt strait to the 385 serious big block? I found a core in excellent shape at the local U Pull this weekend for $130.00 and I'm hoping to get it next Saturday.
@drptop70ss my rear differential is already built with 3.50 gears. i'm not going to back track on that at this point I'll eat the full clip of bullets and build an E40D or Lentech AOD.
Old Jan 14, 2014 | 06:05 PM
  #260
UNTAMND's Avatar
UNTAMND
You'll just need the aftermarket controller for the trans I'm pretty sure. Wouldn't hurt to grab some of the wire harness if you can though.
You'll need an e4od from a 460. There is also one for the sbf but won't work. The bellhousing is integrated into the trans case.
$130 is a good core price. Ask them if the truck run and drove before they got it.
Old Jan 14, 2014 | 06:21 PM
  #261
drptop70ss's Avatar
drptop70ss
A 3:50 gear is not too low to run without overdrive, all depends on your tire height. I used to run a 3:55 with 24" high tires, spun around 2700 RPM on the highway at 65 MPH but it did it. A taller tire would help, 27" tire would get it down to around 2400 RPM at 65 MPH.
Old Jan 14, 2014 | 08:00 PM
  #262
snook715's Avatar
snook715
I'm running a set to 20 inch rims in the rear. Including tires I'm assuming 24 inches tall (very low profile tires).
Old Jan 14, 2014 | 09:51 PM
  #263
drptop70ss's Avatar
drptop70ss
If you know the size of the tires there are plenty of online calculators that will tell you the diameter if you are not near them to measure. Also if you are running a 9" rear there are plenty of good used pigs out there with 3:00 or so gears if needed.
Old Jan 17, 2014 | 02:22 PM
  #264
snook715's Avatar
snook715
Seats are in!
Old Jan 17, 2014 | 02:33 PM
  #265
ALBUQ F-1's Avatar
ALBUQ F-1
Did they weld the seat frame to the pan? I don't think that's a good idea.
Old Jan 17, 2014 | 02:53 PM
  #266
snook715's Avatar
snook715
No sir not yet.
What are your thoughts? Not strong enough...?
Old Jan 17, 2014 | 03:09 PM
  #267
ryans88gt's Avatar
ryans88gt
might have missed it, but what seats are those? I like it.
Also curious what the recommendation is for attachment.
I would worry that if welded to the floor in just one or two places, any even mild fender bender would result in the frame tearing right off the floor. Plus the floor may not support the weight very well long term. Maybe weld to a piece of flat stock or square tubing that is seam welded along the length of the floor?
Old Jan 17, 2014 | 04:31 PM
  #268
DUBS27's Avatar
DUBS27
Those seats look good!
Old Jan 17, 2014 | 05:14 PM
  #269
snook715's Avatar
snook715
Seats
The seats have a few different spots that will be bolted to the sub-frame that is built out of square tube. That sub-frame will be welded to the floor of the cab in number locations and should be plenty strong. Then I plan to put another brace below the cab for seat belts. <o>
<o>
For anyone curious the seats are 2011 - 2013 Ford Explorer 2nd row bench seats from a police cruiser. I purchased a lot auction of seats and kept a few sets for my toys. My items for sale including the seats can be found at the below link. <o
<ohttp://www.ebay.com/usr/snook715
<o<o
The seats feel great! I'll eventually recover them but until that time comes they will work just fine for me and the vinyl will be easy to match for the door panels later. </o
</o
</o
</o
</o
</o
Old Jan 17, 2014 | 06:06 PM
  #270
ALBUQ F-1's Avatar
ALBUQ F-1
I wouldn't weld them at all to the pan. What you need is bolts thru strong pads attached to the seat subframe, with large washers on the underside of the floor pan. Just like seat belts.
