PDA
View Full Version : Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. Seized Distributor
  2. Comparable flow rates of 3 common Y heads
  3. Dummy with a Master Plan - Need advice
  4. Powder Coating Engine Parts
  5. Distributor
  6. will 292 mount up to 3speed trans 56 f100
  7. 59 coming soon
  8. 272 that has outside rocker oilers now change or not
  9. 54 256 water pump
  10. 292 Oil Pump Pickup Tube
  11. new to Y-blocks
  12. Y-block engine ID
  13. 292 performance
  14. 13-tooth, 14-tooth?
  15. 332 Truck
  16. heads
  17. Toploader Four-Speed?
  18. Got a line on a 312
  19. Oils well ends well - I hope
  20. Has anyone put a FE engine in a 292 truck??
  21. Will theese work
  22. heads
  23. Load-O-Matic replacement
  24. Points to electronic distributor info needed
  25. oil pressure
  26. Pictures or links to pictures of Ramhorn Manifolds for Y-blocks
  27. Oil passage blockage
  28. overall dims for a 59
  29. temp sender bushing
  30. tommorrow is D-day
