Distributor
Old Jan 25, 2007 | 10:54 AM
rogerf100's Avatar
rogerf100
Distributor
Does anyone have a y block distributor from 1956 or earlier they would part with? Want to use the shaft for priming the oil. Thanks.
Old Jan 25, 2007 | 10:58 AM
arctic y block's Avatar
arctic y block
Ya got one for a 272 but ya can buy a new dizzy for what it would cost to ship from here.
Old Jan 25, 2007 | 12:43 PM
M6EV139445's Avatar
M6EV139445
I just bought a stainless steel 1/4" hex rod from Small Parts in Miami. 24" for about $8. Just chuck it in your reversible drill.
Old Jan 25, 2007 | 12:47 PM
arctic y block
Somewere about this time ford chanced from a slot to a hex. Be sure what ya got.
Old Jan 25, 2007 | 03:24 PM
rogerf100's Avatar
rogerf100
I know it is a hex shaft since I put it together, 1964 292. I thought someone may have replaced a pre '57 distributor and had a Loadamatic sitting around collecting dust. The 1/4 hex rod is a good idea but then I would have to pull the oil pump shaft out and put it back in. I thought about using a 1/4 socket glued to a shaft. I have one for a 5/16 oil pump shaft. I guess I could find some 1/4 square rod and glue or weld a 1/4 drive 1/4" socket to one end. Thanks.
Old Jan 25, 2007 | 08:56 PM
SpyFoxx's Avatar
SpyFoxx
Let me look, I might have what you are looking for. I will send a PM if I do.
Old Jan 26, 2007 | 05:35 PM
pintoplumber's Avatar
pintoplumber
Someone makes a flexible drive for a cordless drill with diffrent tips, I have one. You can chuck it in your drill and use a tip to get you to a hex drive.
Old Jan 26, 2007 | 07:18 PM
kotzy's Avatar
kotzy
What about a 300 oil pump drive shaft I'm pretty sure they are 1/4 inch.
Old Jan 27, 2007 | 12:01 PM
312's Avatar
312
just use a socket and extension.i think 5/16 fits the shaft.tape the socket on so you dont lose it.you can crank it with a ratchet and it will prime in less than a minute.
Old Jan 31, 2007 | 12:52 PM
M6EV139445's Avatar
M6EV139445
Will a new oil pump draw oil from the pan if the pump is installed empty, that is, without being filled with vaseline or white grease?
Old Jan 31, 2007 | 01:34 PM
arctic y block
Yes. Not a problem.
Old Jan 31, 2007 | 01:43 PM
rogerf100's Avatar
rogerf100
That sounds like a great idea. I will have to check some tool stores for one.
Old Feb 20, 2007 | 03:34 PM
rogerf100's Avatar
rogerf100
I was looking thru a local tool store and found an 11 inch long drill driver with a 1/4 inch drive end that will fit on the oil pump shaft. It is about the same length as the distributor without the cap. It is made by Vermont American. Should do nicely for primng the oil.
Old Feb 20, 2007 | 04:43 PM
46yblock's Avatar
46yblock
Good info rogerf100. Trying to prime the oil in my rig is difficult, with the distributor being so close to the firewall.
Old Feb 20, 2007 | 08:19 PM
arctic y block
Remember the old Flatties? In the front behind the fan under the water pumps?
