Does anyone know of a supplyer for the bushing or it may be called an insert at the rear of the head for the temperature sender ? I need to put one in the right head for an electric fan switch. Tom
Try a supplier here on FTE or one of the many Ford Parts Obsolete stores
Here are the only three part numbers Ford made:
B7A-10911-A Adapter, water temp sender; ..Press in type; 29/32" O.D. x 1/2" long with 1/4"- 18 pipe thread; use with senders having 1/4" - 18 male end.
C3TZ-10911-A ..Press in type; 29/32" O.D. x 1/2" long with 1/8" - 27 pipe thread; use with senders having 1/8" - 27 male end.
C3AZ-10911-A ..Screw in type; 1/4" - 18 external pipe thread x 1/8" - 27 internal pipe thread x 13/32" long; use with senders having 1/8" -27 male ends.
I can get all three of those adapters for you.
B7A 10911 A YOUR PRICE $13.28
C3AZ 10911 A YOUR PRICE $10.13
C3TZ 10911 A YOUR PRICE $15.41
SHIPPING WOULD BE $9.95
Either that or you can call me @ 1-800-532-0819 and I can give you the phone number of the dealership that has the parts in stock.
I found a guy selling them for $7.00 each on e-bay. bought a box of 5 the part number on the box is B4A-10911-A matches the one in my 55 truck. I checked on tee-bird.com they show it for 55-57 t-bird and it's 3/8 pipe thread.
the 10911-b is a 1/4 pipe thread. I have had better luck searching for 1957 thunderbird parts for small engine and ford-o-matic parts.
Sorry guys, I was out of pocket cause the 'puter went down. I also discovered that the sender I need to use is 1/2" pipe!!! So, I guess I am back at square one because there are no water ports that size on my engine. To drill and tap a bushing it wouid be super thin so I'm stumped for the time being. Thanks for all the help though. Tom
