- building a 400
- edelbrock heads
- how bad did i screw up?
- is it a 351m or a 400??????
- '70 351C needs a heavy duty OD Automatic
- charging system diagram
- pump to carb fuel line
- Edelbrock 2171Pk
- Fender well exit headers ?
- 351C Operating Temps
- Normal Operating Temp for 351m
- Anyone dealt with AusFordParts?
- Air Pump ? How important is it ?
- where can I find a 351/400M rebuild kit
- What is up with OEM vs poly engine mounts??
- rods
- cam - how much is too much?
- Model "T" timing control option
- Hedders for 77 F250 4x4
- How do you tell which one...
- Oil Pan availability??
- duraspark
- EGR Use
- Water Pump/Thermostat Compatability
- intake question
- Latest engine projects
- Header coatings ?
- Cork vs Rubber Valve Cover Gaskets
- Strange Humming Vibration & Running Rough at Idle
- dropping oil pressure
