- 5.4L using oil at 39k miles
- How to wake up the 5.4?
- changing oils
- 5.4 stumbles, clears immediately when restarted.
- 5.4 starting to like it's oil, opinions
- How to tell if 3v 5.4L can run E85?
- 5.4 intermittent rattle from valve cover
- 4.6L freeze plugs
- COP Replacement Question
- Running bad. Cant figure it out
- Whats the diff?? 5.4 from F150 to F250/350
- Is It Timing Chain Rattle??
- mustang 4.6 in a f150?
- How to clean throttle body and ports
- 5.4 Oil ports
- 10% Ethanol & Ping ?
- Gas fumes?
- wild 5.4ls in superdutys
- Dual oil filters
- Main and Rod Bearings w/o Disassembling Block
- valve springs
- whats the 5.4L bottom end
- What is the best oil filter to use on the 5.4
- 5.4L oil drain plug
- Right bank dead
- 2000 F350 5.4 no start problem
- 5.4l oil issue
- 2000 F250 5.4l Cylinder heads
- BBK Throttle Body F-350 5.4 Need # Or A Pic
- Misfire?
