2009 4.6 sparkplug question.
Old Oct 7, 2020 | 12:30 PM
6t6merc's Avatar
6t6merc
I have little knowledge of these engines, but I have heard a lot about the spark plug problem.
I want to remove the plugs from a 4.6 and test the compression. (If it is relevant, the motor is the police version with under 200,000 km.)
Did Henry fix the problem by 2009, or am I in need of your advice?
Thanks, Eric
Old Oct 8, 2020 | 04:44 AM
JWA's Avatar
JWA
In general ejected spark plugs from the Modular Motors is largely over-stated, IMHO anyway. Yes it does and has happened but it tends to happen within the first 100K miles and almost always a direct result of improper installation or failure to check spark plug torque. When replacing plugs its best to use nickel-base anti-seize and increase torque between 23-25 ft/lbs each.
I've dealt with a total of 6 E-Series with 5.4 motors, each one with well over 150K miles and not one issue with spark plugs. COP failure is also rare when using the better brands.
HTH
Old Oct 8, 2020 | 07:09 PM
Johnny Paycheck's Avatar
Johnny Paycheck
You have the old school 2V 4.6 then. No fussing with broken plugs like the 3V 4.6 and 5.4 were known for.
Old Oct 9, 2020 | 05:01 AM
JWA's Avatar
JWA
Broken 2 piece spark plugs in the 3V heads is quite a bit different from ejected spark plugs most commonly found in the earliest 2V engines. I don't recall many issues with ejected plugs in the 3V heads.
Old Oct 9, 2020 | 06:41 PM
6t6merc's Avatar
6t6merc
Maybe I have it wrong - I thought they often broke when screwed out of well-used motors. No?
Eric
Old Oct 10, 2020 | 05:40 AM
JWA's Avatar
JWA
Eric
I don't know if your year 4.6 has the two piece plugs but typically the Modular Motor spark plugs don't present too many problems if they've been installed correctly or were changed at least at the 100K mile interval factory plugs are touted as being that long-lived. It would be helpful to you knowing whether they've been changed at some point before you came to own the vehicle.
Otherwise there is or should be a ton of great info about dealing with potential spark plug issues here on FTE or YouTube. Here's a very basic tutorial on plug removal if its on a 3v motor:
There are any number of similar videos dealing with removal of a 2 piece plug that has broken during removal, one example:
Hope this helps!
Old Oct 11, 2020 | 02:26 PM
6t6merc's Avatar
6t6merc
Thanks for the help.
Eric
krisinwa
2004 - 2008 F150
Nov 11, 2017 10:43 AM
F-150fireman
Modular V8 (4.6L, 5.4L)
Apr 10, 2015 06:33 AM
xjcamaro89
2004 - 2008 F150
Sep 14, 2010 06:54 PM
dcramp
1997 - 2003 F150
Dec 1, 2007 10:05 PM
