Wiring help please
Old Oct 16, 2020 | 06:51 AM
Marct's Avatar
Marct
Wiring help please
Hi all, hopefully this is in the correct section as I wasn’t sure if it should be here or the electrical section. I’ve also done a search and couldn’t find a post with the attachment still live.
I’ve got a 56 with a 99 Crown Vic 4.6. It has on plug coils, EGR, EVAP (well some of it) which is missing. I’ve rewired the OBD2 socket and got fault codes form the Evap pressure switch and all 4 o2 heaters. While these most likely aren’t the misfire I would like to get the o2 heaters working. Does anyone have a wiring diagram for the engine management they wouldn’t mind sharing. (I did order the Haynes manual but nothing about engine wiring sadly)
Also does anyone know the fuel pressure for this engine as I’m planning to test the fuel pressure and cylinder compressions.
Thank you.
Old Oct 17, 2020 | 05:25 AM
JWA's Avatar
JWA
I think you would want an EVTM from 1999 Crown Vic models---should be one on eBay I'm thinking. Check this listing: 99 Crown Vic/Grand Marquis EVTM
Old Oct 19, 2020 | 03:47 AM
Marct's Avatar
Marct
Thank you. I’ve ordered one.
It was starting but now decided not to and running rich still with the faults. Hoping it’s wiring as it wasn’t wired great. My plan is I need to know it runs good before I start stripping for the other jobs
Milwaukee1979F150
Jun 1, 2011 02:04 PM
Rust is too a color
Jul 20, 2010 11:10 AM
fredweberjr
Jul 27, 2008 04:44 PM
Brian794x4
Aug 28, 2005 09:50 PM
