Smoke from tailpipe (read)
Old Jun 18, 2020 | 04:53 PM
turborich's Avatar
turborich
2001 4.6 liter, dealer maintained its entire life, runs, idles, excellent. 160,xxx miles. No smoke on cold starts, none! Only puffs blue smoke (oil) when at full operating temperature after idling for a few minutes. Everything is pointing towards valve seals, except that there's no smoke upon card start ups. That's when you'd expect it to smoke the worse. Any ideas here? Still running 5w20 synthetic oil. Do these engines have a valve or anything that could allow for oil consumption only when fully warmed up? Thanks.
Old Jun 19, 2020 | 06:45 PM
z31freakify's Avatar
z31freakify
Nope these engines a pretty much bullet proof. Take a peak inside the oil fill and see how clean it is, report back.
Old Jun 20, 2020 | 05:00 AM
JWA's Avatar
JWA
Its maybe possible the PCV needs replaced? Unfortunately the described symptoms don't remind me of anything I've experienced or read about here on FTE.
Best of luck with this!
Old Jun 23, 2020 | 11:23 AM
alloro's Avatar
alloro
I would say to look inside the PCV hose for oil. If you find oil in there then you might have a high level of piston ring blow-by.
Old Jun 30, 2020 | 09:40 PM
turborich's Avatar
turborich
Inside of the engine is probably the cleanest I've ever seen from looking into to oil fill. Engine oil stays super clean for a long time. Installed new PCV valve, no blow by when oil.fill cap in removed while running. That's why I'm thinking valve seals. If I let it idle warm for 5 minutes it will give a blue puff.
Old Jul 2, 2020 | 04:07 AM
JWA's Avatar
JWA
^^^I'd agree valve seals could be going away, the blue puff being the biggest clue I think. My experience has been the blue puffs that are most visible during the day's first start up meant fairly severe leakage sitting still for a time. Mind you that was mostly GM small block engines of various years, I'm sure Ford's Modular Motors are quite different in the valve stem sealing design.
Old Aug 21, 2020 | 03:18 AM
turborich's Avatar
turborich
Update, I'm pretty sure it's the valve stem seals. I switched over to Valvoline 5-30 high mileage semi synthetic and after several hundred miles it's almost all the way cleared up. Now just to be clear, this engine has been maintained from the Ford garage it's entire life and has always had 5-20 synthetic oil changes on time. I think it's just a fluke that it started puffing oil, but once again, only after idling for extended periods, not first thing in the morning and for all I know it may only be one seal, who knows? Just wanted to say this so a guy with an old beat up engine doesn't think the high mileage oil is the cure. For me it's certainly helped.
jbizub5192
6.7L Power Stroke Diesel
15
Nov 16, 2022 12:28 PM
Joe Finn
1997 - 2003 F150
Apr 21, 2008 11:23 AM
browntown3
Modular V8 (4.6L, 5.4L)
Jan 11, 2008 05:49 PM
Ben34
3.8 & 4.2L V6
Mar 28, 2007 10:55 AM
relicpelican
1997 - 2003 F150
Sep 2, 2006 10:57 AM
