Engine Bogs down when pressing Accelerator
Old Sep 25, 2020 | 01:22 PM
caleboc73's Avatar
caleboc73
I have a 2003 F150 Lariat, and I am having issues with the truck moving when you step on the gas. It feels like it bogs down and starts sputtering and will barely move. It just out of the blue started doing that. I have replaced all the plugs, and coil backs, EGR, Throttle body censor, Fuel pump, fuel filter, checked the catalytic converters, map censor, and I am just stumped. Nothing I have done is working, You can step on the gas lightly and it will barely start moving, but if you try to step on it normal, it bogs down like its about to stall.
Any suggestions?
Old Sep 25, 2020 | 03:18 PM
lv2race's Avatar
lv2race
Check for codes? Check fuel pressure? Check fuel pressure regulator vacuum line? Possible FPR problem?
Old Sep 25, 2020 | 05:47 PM
caleboc73's Avatar
caleboc73
codes were clear, fuel pressure was good no issue on vacuum line. Not sure about the FPR.
Old Sep 27, 2020 | 05:21 AM
JWA's Avatar
JWA
Have you cleaned or inspected the throttle body itself? Its not a tough task to remove it for a thorough cleaning.
mark88mark
Aug 3, 2010 01:10 PM
bhuff
May 14, 2008 02:11 PM
RJF88
Aug 7, 2007 12:33 PM
mzsparkee
Apr 14, 2007 07:43 AM
pdonis
27
Feb 21, 2004 04:29 PM
