5.4 help
Old Jul 26, 2020 | 04:21 PM
Forestrat's Avatar
Forestrat
5.4 help
07 5.4. Started my truck after setting a month.and did like always high idle then backfired and run like crap. A rat took of running... So popped the hood and seen a nest under intake.. Wire chewed to knock sensor... Ok pulled intake. Replaced sensor. And a couple other chewed wires to abs sensor no big deal... Fired up. And still run like crap... I figured why not change all timing components phasers solenoids. Etc.. Run like crap still. P0018 p0022. So pulled apart advanced the cam and got a whole slew of codes. Multiple misfired rich etc on bank 2... So pulled again and retarded cam a tooth. Back to. P0018 p0022. So pulled again. Triple checked all timing. Still same codes... I'm about to burn it.. Bad new parts? Maybe missed a chewed wire? About to just pull valve cover and use a chain breaker to advance the cam again..... Bank 2 driver side. Driving me nuts... Any suggestions? Anyone have ECM pin locations to check if I missed a chewed wire to cam sensor ?
Marks are on spot
Old stuff
Rat damage.... Possible to harness i missed? You can see insulation damage on firewall
JP3
2004 - 2008 F150
30
Feb 9, 2022 09:15 AM
Night0wl
Jun 5, 2020 06:53 AM
gpineau
Mar 31, 2018 11:14 AM
countryboy116
2004 - 2008 F150
Nov 1, 2011 06:44 PM
