- 1985 F150 5.0 MPFI sensor specs.
- 85 F250 300 with feedback carb with high idle after warm up. ECT sensor missing!!
- Where did all the compression go?
- 82 F100 Sputtering Issues
- Inline 6 carb upgrade
- 83 to 86 clock wiring extension ?
- Fuel Additives
- 1986 F250 fuel gauge misreading
- 1985 F150 5.0 MPFI ECU problem
- Chassis interchange questions
- Looking for Dually Measurements
- Clutch Pedal.
- In-carb fuel filter - what kind of threads?
- Help in finding parts for 1986 F-150?
- 1986 bronco from under a pick up cab and front end
- Vacuum and brake issue
- ford 8.8 options
- tuning the carb
- 84 F250 6.9 idi Adapter plate broke...
- 1985 F250. Wanting bigger tires
- Need help with 1984 ford f150
- New guy '85 f150 introduction.
- can i bypass the oil cooler safely
- power steering box - rebuild, replace, or repaint
- Timing a 1980 400 cid
- Pulling to the left without breaking
- 351w HO running really rich help!
- Wiring Question for 1985 F150 5.0 MFPI
- broke my wing window handle
- Hard start when engine is hot.
