Fuel Additives
Old Nov 9, 2012 | 07:37 AM
datsun147's Avatar
datsun147
Fuel Additives
Hi all I am getting ready to make a 1400 mile trip with my 1986 F 250 4x4 it has the 460 (7.5)engine with a 6 man slide in camper and towing my 1995 ranger. I am leaving denver co going to washington state my question is are any of the fuel additives worth buying? I was thinking the octane booster may be cheaper than filling up with premium gas. All ideas welcome. and thank you in advance
Old Nov 9, 2012 | 10:52 AM
Yaga1973's Avatar
Yaga1973
Elder User - What???
Why would you need to use premium grade fuel?
Old Nov 9, 2012 | 11:29 AM
joshofalltrades's Avatar
joshofalltrades
you see lots of huge promises, but in reality, pump gas is pretty good and has all the necessary additives already in it. just buy quality gas, not arco, 7-11, or "henry's no-name food store" gas, and you'll be fine
Old Nov 9, 2012 | 11:55 AM
Franklin2's Avatar
Franklin2
Has your truck been rejetted for high altitude(Colorado)? If so, it may need some carb work to get it runnng right if you are going to use it at a lower altitude.
You should not need any fuel additives. They do work, but I have only used them when I have gotten a tank of lousy gas.
Old Nov 9, 2012 | 11:53 PM
Swatter's Avatar
Swatter
I sometime add marvel mystery oil, seems to run better with it, maybe its improving the compression.
Old Nov 10, 2012 | 05:56 AM
datsun147's Avatar
datsun147
Thanks all for your input guess i was just trying to get better than 8 mpg anyway i could. Ill just stick with a top brand name gas. the carb prolly wasnt jetted for high altitude as i bought it rebuilt on line out of texas a holly 4 barrel. so even with the big 460 i dont need premium regular unleaded will be fine?
Old Nov 10, 2012 | 06:41 AM
Franklin2's Avatar
Franklin2
It's supposed to be able to run on 87 octane from the factory. If it pings, you may need to check the timing.
Carolina78
Jan 9, 2013 04:33 PM
ravens fan
May 9, 2011 06:30 PM
hollenjoe
Sep 19, 2008 09:45 AM
poppie
Modular V10 (6.8l)
Oct 21, 2007 08:04 AM
tscryba
2004 - 2008 F150
Sep 11, 2004 09:51 AM
