Inline 6 carb upgrade
Old Nov 9, 2012 | 11:21 AM
swmr1's Avatar
swmr1
I have a 1983 f150 inline 6 and i want to put a 4 barrel carb on it. What size should i get? What mods will it take to install it? How would i get the transmission kick down to work with the new intake required for the carb?
Old Nov 9, 2012 | 11:59 AM
1986F150six's Avatar
1986F150six
Welcome to the forum, swmr1!
Scroll down to the inline six forum and there is a bunch of guys who drive, work on and discuss six cylinder upgrades all the time.
A fellow member, AbandonedBronco, has done just what you are asking about on two Broncos, except his have manual transmissions.
Franklin2's Avatar
Franklin2
You need a very small carb. Most use the 390cfm holley, but I believe some have also used the 500cfm edelbrock. Maybe they will comment on how it works for them.
You need to consider the whole package, it's not easy turning a inline six truck into a firebreather to compete with the v8's. The six is a low rpm engine for pulling, and changing it's personality also may require a gear ratio change in the rearend.
Old Nov 9, 2012 | 12:31 PM
swmr1's Avatar
swmr1
I'm not trying to make it a fire breather by any means. I'm just trying to give it a little more pep and do a little better off road. I have already re geared it. It just seams not have the fuel flow on the highway. It tends to have problems going up hill and any thing over 65.
Old Nov 9, 2012 | 12:38 PM
1986F150six
What rear end ratio do you have and what size tires?
Old Nov 11, 2012 | 12:06 PM
swmr1's Avatar
swmr1
4:10 with 35 inch km2
scarfo
30
Sep 2, 2017 01:53 PM
AbandonedBronco
24
Feb 5, 2011 09:20 PM
timothy_10982
Jun 24, 2008 01:31 PM
Blue50F-1
Mar 6, 2008 09:57 AM
Vampiro
Aug 12, 2002 09:59 PM
