- 4.9 stalling when warm, difficult to restart.
- Idle briefly staying high
- Carb float measuring
- 1993 F250 4x4 Engines. Which one should I pick!!??
- 89 F-350 7.5l won't start
- what the heck is this thing,,,fell out of truck
- Planning engine re-seal - 88 F150 5.0L
- 91 f150 no spark
- Fuel Filler Neck/Hose Issue
- Axle pivot bushings R&R steps?
- 96 obd2 dash work in 97 obd1
- Transfer case conversion
- D60 is supposed to have a rear leaf shackle...right?
- Which u-bolts for D60 should I use?
- What's this plug? (87-91)
- 5.0 aod swap. Hesitation
- Retiring my truck, looking to make it a project. Ideas?.
- Fuel injection to carb 86 to 88
- 235/85/16 tires fit on 92 F150 wheels?
- 3/4 ton springs onto 1 ton
- 1996 F250 7.3. Bad ECM? Bad injectors?
- Brake lights staying on constantly
- 1991 f150 clutch starting problem
- Was asked to make a second thread...1990 F150 302
- 1990 Super Duty 7.3L Oil filter adapter
- Exhaust system question
- another smog delete Q
- Whats next?
- 1994 460 F-250 transmission upgrade question
