Idle briefly staying high
Is this normal? The idle stays up then goes a few seconds after I give it throttle. The solenoid holds the idle up then releases. I just rebuild the carb but it did the same thing before. I also replaced all the plug caps and vac tested lines. Also checked the intake manifold for air leaks. New carb base gaskets also.
The truck is in operating temperature and was driven 20 minutes.
87 300 carter yfa.
Watch in full screen view and click options to watch in higher resolution.
87 300 carter yfa.
‘66 F100 Pearl
11-28-2018 01:07 PM
Rij1
04-14-2017 08:50 AM
old timer
06-18-2000 12:16 PM
