- Warm oil temp???
- MPG Gauge Question
- steering wheel jerking violently
- No start and codes.
- Odd 6.0 Problem
- Stock 06 Blowing Black Smoke
- How can you tell what Flash is in your truck?
- Pressure Test
- Problems persist: Oil Cooler Plugged, Questions.
- racking my brain on a 6.0 problem, need ideas
- Stumped.. HG or EGR? Coolant Loss
- Pressure Guages
- overfuel @ idle no rev past 2500 HELP!
- Hows everybodys trannys holdin up?
- newbie needing info
- degas bottle puking a little and white smoke at start up
- Turbo fart = clean the turbo?
- Engine stumbles
- 6.0 Powerstroke suggestions
- On The Road Again
- dummy plugs + standpipes. now as preventative or wait?
- probably dumb scanguage II ?
- coolant cap leak
- F-350 cross drilled rotors??
- Gauges
- Just bought 06 F350 FX4 6.0!! :D
- Hows everybodys VGTs holdin up??
- No A/C Or Heat
- Turbo over busting after a service
- Replacement Front shocks
