No start and codes.
Old Jul 18, 2012 | 06:29 PM
StrokinWarmblood's Avatar
StrokinWarmblood
No start and codes.
Hey folks, to make a long story short: Had codes for FICM, and 3 Injectors and ICP too low. Switched out FICM with a Bostech rebuilt in the driveway, now it's only throwing ICP too low (P2291) It will not start, not even sputter. Any ideas? I'm thinking HPOP.
Old Jul 18, 2012 | 06:42 PM
Rusty Axlerod's Avatar
Rusty Axlerod
You could unplug ICP and see if it will start with default value to verify the HPO is actually low or bad ICP. Is the ICP on passengerside valve cover or under turbo on your '04?
Old Jul 18, 2012 | 06:44 PM
StrokinWarmblood
It's on pass side cover. Going to go try will report back
Old Jul 18, 2012 | 07:17 PM
StrokinWarmblood
No dice. Unplugged it and still nada. Any more clues?
Old Jul 18, 2012 | 07:56 PM
BLADE35's Avatar
BLADE35
OEM Oil Filter CAP??????????????
Does the Dash Oil Press Gauge Register on Long Crank????
Any Recent work
Old Jul 18, 2012 | 07:58 PM
StrokinWarmblood
Stock cap and yeah it does
StrokinWarmblood
Sorry I don't mean to be short. I'm on my phone
Old Jul 18, 2012 | 08:10 PM
BLADE35's Avatar
BLADE35
Its OK
Time for an Air Test dont look like your getting off to easy
I beleive you have standpipes and Dummey Plugs and since your going in that far just as well rering Injectors to Aliant Power has the Ones you want with the Top Injector oring for the HPO Rail to inject connect
But Do an Air Test and see if you can hear it in the Valve covers or if you hear in the oil filter housing then That Means HPOP
Do the air test and see what happens IMO
Old Jul 18, 2012 | 08:12 PM
StrokinWarmblood
What's an air test? Is it in tech folder?
Old Jul 18, 2012 | 08:17 PM
BLADE35's Avatar
BLADE35
You hook Air compressor to the HPO system at t6he ICP Port give IPR 12volts to close it that makes the air go into HPO system with IPR Closed the HPO is singled out then listen for leaks
I did forget to mention you can Pull and Inspect IPR Screen for Damage was there any recenrt work???
Old Jul 18, 2012 | 08:18 PM
StrokinWarmblood
No recent work that I'm aware of. I will do that test tomorrow and ask the owner about recent work.
Old Jul 18, 2012 | 08:20 PM
BLADE35's Avatar
BLADE35
so its NOT the truck in your SIG????????????????
StrokinWarmblood
Negative. This is a friends 2005.
Old Jul 18, 2012 | 08:29 PM
BLADE35's Avatar
BLADE35
Well That Changes things Some
I thought it was your 04
So being this truck is an 05 Has he Updated any of these Parts
STC Fitting
Standpipes
Dummey Plugs
High Failrate for these on an 05
Old Jul 18, 2012 | 08:30 PM
StrokinWarmblood
That's a big negative. None of these parts have been replaced. I appologize, forgot to specify.
