- Injector help!
- Lower boost
- HFCM drain threads are stripped
- 2004 Ford F350 6.0 no start
- Weird Turn signal/dash indicator issue- Ford Techs please read!
- FICM Connector repair-with pigtail???
- Check turbo vanes through the service port for correct operation?
- 5R110 died!
- HPOP and oil shear
- major air leak on hpop air test!
- Joining the Studded Club
- Got some new toys to install. (Pics)
- What should I do next?
- Torque App not reading all PIDs
- Can I mix Valvoline Maxlife with Mercon LV in the TorqShift?
- Scangauge II
- low boost
- Dash light mystery
- 05 needs work
- How long are you keeping it...
- Two bad alternators in 3 months?
- Moaning Brakes with Vibrating Brake Pedal
- Well...
- Could it be time?
- What is the best oil cooler?
- Rotors
- 2004 f350 maf sensor
- Which Steering Damper?
- OMG I CANT BELIEVE I DID IT!
- Bad EGR valve?
