Lower boost
Old Mar 11, 2016 | 02:09 PM
Mike2006 powerstroke's Avatar
Lower boost
I have a 2006 Ford F-250 6.0 Powerstroke I have oringed heads arp head studs egr delete Reg fuel return set to 58 airdog 2 fuel system stock injectors 4" exhaust to 4" muffler new cold and hot side intercooler pipes and boots new bigger intercooler and mtw stage 2 turbo and on a custom tune for that turbo I can't make more then 28 psi max wot and I have taken off the Ebp sensor tube and cleaned out and replaced the sensor has a new map sensor new iat sensor and new computer and new up pipes I'm stumped and the Ebp sensor reads 2-3 at idle and 34 at wot and the Vgt never goes below 15% at wot and never over 78% at idle cold I'm stumped!
Thanks for the help In advance! Mike
Old Mar 11, 2016 | 04:01 PM
WatsonR's Avatar
WatsonR
The wrench light will come on above 28lbs.... custom tuning prevents that, its that way on purpose, at least mine is.
VGT max is 15 and full closed is 85. If it goes lower than 15, it's probably broke. 77 probably average at idle, 20 or so at WOT.
Lots of good reading here to get a handle on things.
I've seen no more than 44 on EBP. But it sounds like your trucks working fine.
Old Mar 11, 2016 | 05:44 PM
The guy that build it said it should be putting out 35 psi and I'm only getting 28 I want to get an aftermarket boost gage and when the torque converter locks up it lags and instead of building boost it loses it. So my egts get high I want to get the boost back up not sure what's up with it! Also forgot to mention I have srl+ tune on it and does the same stock
Old Mar 11, 2016 | 07:02 PM
WatsonR's Avatar
WatsonR
I'm running SLR Extreme and an Atlas 40 FICM tune. I get 28lbs exactly, but I also know it's more than that. An aftermarket boost gauge will tell you for sure.
Old Mar 12, 2016 | 12:27 AM
What are your egts? Like crusing on a flat road going 70 it will be 650-700 then aproching a hill it will kinda bog down and if I keep my foot on the peddle like 1/4 throttle it will go high as 1100-1200 not sure if that's night or not
Old Mar 12, 2016 | 08:17 AM
WatsonR's Avatar
WatsonR
I run 600-700, sometime less. If you lug the truck, EGTs will increase during a hill climb. The trick is to make the truck down shift and get the boost and RPM to come up, that increases air flowing to cool the truck.
I can hit those numbers on a heavy throttle run.
Your truck is acting fine. You've got all the right stuff to lower EGTs... large exhaust, bigger turbo, custom tuning and a gauge to warn you before its to late.
Whats the MTW stage 2 turbo?
Old Mar 12, 2016 | 02:19 PM
It's made by Adrain at mad turbo works it's a 64mm I believe and has a bullet wheel in it
Shaun Fed
6.4L Power Stroke Diesel
Jul 25, 2019 05:12 PM
53jimc
Nov 19, 2018 06:53 AM
xrsfsho
May 12, 2017 05:50 PM
superstroked6.0
Oct 23, 2016 06:18 PM
lsramek1
Nov 28, 2011 08:47 PM
