- Oil leak under turbo and whistling sounds
- Oil cooler change with possible EGR delete.
- 2003 egr delete and DTC question
- How is my truck doing????
- SCT Eric's Tunes. Injection Control Pressure down with tuner and fine without?
- Low Boost Question - 25 rather than 29
- Latest Flash for 2004?
- 6.0 engine stumble under a load
- Transmission drain plug issue
- I've beaten this to death but one more question for you motor techs
- Superchips or Hypertech?
- level kit installed
- MAJOR ISSUE, starting, NEDD HELP!!!!!!
- 2005 F250 Running Rough After Started Up But Then Goes Away.
- Transmission Warning Light
- How do you test HPOP and ICP with Autoenginuity.?
- Doing the AirDog II, need help!
- 2007 psd and better than the older ones?
- Dropped Bolt from HPOP Cover
- Another SCT Question
- coolant filter ??
- Heavy Duty egr cooler
- ficm question
- Why would someone pay to be a member? How do u get responses.
- Fuel pressure gauge
- electrical gremlins
- Questions about 6.0s from an outsider
- Oasis report?
- Gauge Setup..
- Best tuner for the buck???
