Transmission Warning Light
Old Aug 29, 2010 | 07:46 PM
04HD's Avatar
04HD
I left home pulling a 10K trailer and after 15 miles the transmission temp guage pegged out as "Cold" and the tow light starting blinking. Transmission didn't seem to have any problems. Any ideas what's going on? Do I need a fluid change? This truck has 190k miles. Thanks
Old Aug 29, 2010 | 07:48 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Describe the year/engine etc of the truck, please.
Old Aug 29, 2010 | 07:54 PM
04HD's Avatar
04HD
2004 Super Duty 6.0 Diesel
Old Aug 29, 2010 | 07:56 PM
BigBlue04's Avatar
BigBlue04
My money is on the Transmission Fluid Temperature Sensor....... I had the same issue about a year ago.
It's a pretty easy fix if you've got about an hour. You have to drop the pan to replace the sensor.
Old Aug 29, 2010 | 07:58 PM
jetact's Avatar
jetact
My quess is a little more love then that is needed. When my truck at 42,000 mile started flashing the tow light I got a new tranny. Check the fluid level and can you check codes?
04HD's Avatar
04HD
Thanks Matt. I will give that a try.
Old Aug 29, 2010 | 07:59 PM
04HD's Avatar
04HD
Fluid was at correct level.
Old Sep 12, 2010 | 07:05 AM
04HD's Avatar
04HD
Problem was temperature switch inside pan. Thanks for all your help.
Old Sep 12, 2010 | 07:06 AM
04HD's Avatar
04HD
Thanks Matt, problem was temp sensor inside trans pan. Thanks for your help..
Old Sep 12, 2010 | 01:10 PM
jetact's Avatar
jetact
Thumbs up to big blue on that diagnosis.
jahrenholtz
Jun 6, 2016 07:07 AM
willbd
May 27, 2014 08:46 PM
wta143
Jan 4, 2011 05:33 PM
hacksaw830
Feb 9, 2009 01:29 PM
mikevv
Oct 22, 2005 11:21 PM
