How do you test HPOP and ICP with Autoenginuity.?
You can monitor any number of Injector Control Pressure PID's. I don't remember what they all are. You can also go into the activation screen and set the Injector Control Pressure and watch the PID change to the value you set it to. The motor will stumble when you change the IPR value, as the injector pulse width automatically adjusts to maintain idle.
You can also increase idle to do these tests at higher engine speeds.
I'm not exactly sure why you'd want to do this, except to see that the ICP sensor and IPR are working right. But is a lot of fun to mess with things and see what happens.
Is there any way to do it just using AE without going under the hood?
And if so what are the numbers I'd want to see?
I am planning on installing a new turbo and figured if I am in there I may as well change the ICP when it's easier to get to if needed. If I can't test it is it just worth the cost of doing it now anyways? My truck has 140,000 miles on it.
No issues, just thought if I was able to test the icp I could havE a better idea whether to replace it while the turbo is off. I suppose it's preventative maintenance. My truck is an early build '04. I'm installing the new Garret powermax and some 190cc injectors in the next month. I thought it would be good to somehow test the hpop, icp and any other systems before the upgrades. Also thought if there where readings I should be noting for a bench mark before the upgrades.
nuknuk
08-22-2016 04:55 PM
60, autoengenuity, autoenginuity, bench, diesel, ford, hpop, icp, powerstroke, pressure, scan, sensor, test, testing, tool
