Fuel pressure gauge
Old Aug 29, 2010 | 10:40 AM
pnj442's Avatar
pnj442
Fuel pressure gauge
I checked the tech folder and didn't see the procedure for installing a fuel pressure gauge. It's early and I haven't had my requisite 3 cups yet so I very well could have missed it. Is there a writeup somewhere on the installation preferably with pics. If someone could point me in the right direction is would be appreciated.
Old Aug 29, 2010 | 10:48 AM
npccpartsman's Avatar
npccpartsman
If you've installed the "blue spring", the fuel pressure test port is just to the left of the spring housing. The plug/fitting size is M12 x 1.5 and needs to go to 1/8" npt. It requires a 6mm allen wrench to remove the plug. Sinister diesel/ITP sells an adapter hose and I'm sure some other vendors also. It lets you get the gauge sending unit away from the engine vibration and to mount it in a secure place. You can then run the wires through the firewall to a gauge mount location of your choice. No fuel in the cab!!!
Here's a link to the adapter hose: http://www.sinisterdiesel.com/store....60L_FP_Adapter
Old Aug 29, 2010 | 11:07 AM
pnj442's Avatar
pnj442
Thanx. Going to get it done Monday. Sunday is football day if ya know what I mean
Old Aug 29, 2010 | 11:10 AM
npccpartsman
Saturday AND Sunday....I'm more of a college football fan, but I love ANY kind of football. PERIOD.
Old Aug 29, 2010 | 11:27 AM
pnj442's Avatar
pnj442
I stand corrected.
Old Nov 29, 2010 | 12:10 AM
chadjones99's Avatar
chadjones99
Here's a link to the adapter hose: 6.0L Fuel Pressure Adapter
dont you need a male fitting to thread into the side of the fuel filter bowl ? meaning the link for the Adaptor shows hose with fitting but they all look female ?
Old Nov 29, 2010 | 04:17 AM
moebdick's Avatar
moebdick
The Sinister Diesel hose comes with the M12 x 1.5 male fitting. Depending on how big your fuel pressure sender is, the adapter hose may not be needed. I bought an Isspro EV2 and mounted the sender directly on the fuel bowl using a 45 NPT elbow attached to a M12 x 1.5 adapter. The 45 elbow was needed because the radiator hose is in the way. Here's a pic of the sender (wires not attached).
Old Nov 29, 2010 | 05:58 AM
chadjones99
thanks , ya thay dont show the male fitting in there ad ?
Old Nov 29, 2010 | 08:52 AM
texans's Avatar
texans
Yeah, I don't know why they don't show the adapter in the photo, but it does come with everything you need to hook that up to the fuel bowl. At least when I got it it did.
Old Nov 29, 2010 | 09:45 AM
High Binder's Avatar
High Binder
FYI, I had to use one 3/8" 90* elbow to get my sender to fit without hitting a CAC tube.
Old Nov 29, 2010 | 01:26 PM
Hank85713's Avatar
Hank85713
I went to a hose supplier and bought a barbed connector, hose and the adapter for about $10. Mounted the sender to the rad support used about 2ft of hose to hook it all up.
Two_Ton21
Feb 4, 2014 07:52 PM
Granpa's76
Sep 6, 2013 09:09 PM
bigbeariron
Jan 10, 2012 04:50 AM
Ford Runner
Sep 27, 2010 09:16 PM
teppler
Mar 1, 2010 04:05 PM
