- question about clutch adjustment, pedal
- Got my new axle
- '83 Borg Warner T5 out of a CJ7 into my '66 F100?
- 6.9L bellhousing
- 94 F150 inline 6 4.9 liter
- swap 1/2 to 9/16 wheel studs on rear Dana 60?
- ZF S5-42 shifter
- Weird clutch slippage
- E4od
- trouble shifting
- Front End Diff Rebuild...
- Help! can you replace a c6 with e4od
- Who knows C6 transmissions?
- C6 vs E4OD ?
- E4OD No Go when hot; works cold - ideas?
- 9" axle retainers
- tranfer case problem
- Squeeling Transmission
- 1979 transfer case oil type?
- striped screw on lock out hub
- 1985 F350 w/4 speed AND DUAL RANGE?
- Axle Removal Help needed.
- Driveshaft Removal
- 87 tranny trouble getting it into gear
- 84 C6 locking up in first gear??
- c6 trans
- Help with axle code.
- Spindle on dana 50 and 60 the same?
- space between bellhousing and engine
- transmission
