- Transmission problem....
- e40d on 94 f 250 shifts to hard and fast.
- C4 slipping in all forward gears, what level of rebuilt kit do I need?
- Looking at an old NP435
- 2007 f250 limited slip how does it work?
- What transmission do I need
- $699 E40D rebuild?
- what parts do i need to reattach yoke onto 86 sterling axle?
- Rebuild Instructions Needed
- C-6 Transmission Fluid pan issue
- Transfer case problem
- Best Tranny To Put Behind A Built 7.3L
- ID this tranny
- Calculate/Confirm gear ratio
- ZF Mystery...?
- 1986 F150 Hard to shift while running
- E40D won't downshift from overdrive
- E4OD - '91 F150 No Reverse or Neutral
- new clutch not working
- No Gears for E4OD
- slip yoke leak
- What transmissions can be used with a 351w?
- Dropped my e4od pan
- Sterling 10.25 axle shafts in a 10.5?
- E4OD I'm lost!!
- Trans to T-case match up between ZF-BW 1345 T-case
- locking hubs
- How warm do rear axles get?
- 11 in. clutch to 11 1/2 in. swap
- hate to ask another E4OD question, BUT...
