transmission
Old Sep 23, 2005 | 11:52 AM
wfoster's Avatar
wfoster
transmission
I have a 4wd F250 diesel 1986 190000km. I get alot of chatter when I let the clutch out on an incline. What would cause this? What is the sequence of testing to isolate the problem?
Old Sep 23, 2005 | 02:42 PM
fordborn's Avatar
fordborn
Thread moved to " Clutch,Transmission, Differential, Axle and Transfer Case" technical forum. Should receive more responses to your question here.
Welcome to Ford Truck Enthusiasts. We are glad you chose to visit our site.
Please view the main forum page to find the best forum to ask any Technical questions
Also, below some of the titles of forums there is text that explains what the forum is either for or what shouldn't be posted in it.
Then ,Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums all user's can make their relationship closer to others by visiting & joining the State/Province Chapter that relates to their location.A complete list of Chapter's is located on the main forum page, near the bottom.
Once again...Welcome to the FTE Family
Old Sep 23, 2005 | 04:24 PM
l-m tech's Avatar
l-m tech
sounds like the flywheel has hot spots on it causing it to chatter and shake.resurface it.
Old Sep 26, 2005 | 09:36 PM
wfoster's Avatar
wfoster
Would oil on the clutch or a broken motor mount have the same symptoms? Again, the chatter happens when the clutch is under load. I also noticed that after a long trip 6-8 hours driving that the chatter happens even under light clutch loading
Old Sep 26, 2005 | 09:54 PM
Jspafford's Avatar
Jspafford
How old is the clutch? Sound like it may have oil on the disk, or just be plain worn out..
Old Sep 26, 2005 | 10:18 PM
wfoster's Avatar
wfoster
The clutch has 190000km(approx 120000miles)The chatter only happens starting off in 1st gear when I'm on a hill. If I use the transfer case to start off I don't get chatter!
Old Sep 26, 2005 | 10:20 PM
Jspafford's Avatar
Jspafford
I would say the clutch had a good life on such a heavy truck. Baby it, until it starts to slip while trying to accelerate, and then replace it.
