E4OD No Go when hot; works cold - ideas?
1991 F-150, 302, E4OD. Blew the front seal recently & replaced the pump seal, torque converter & filter. Ran fine for several weeks, then quit completely. Current symptoms:
When starting cold, it will pull & shift, apparently correctly. After it warms up (3-5 minutes), it will not move in any gear position.
Fluid is full & clean. Any troubleshooting I can do before I pull it & rebuild or replace it?
Thanks,
Mike in Tennessee
Thanks,
Mike in Tennessee
