- Stall Speed
- Adjusting shift points???
- Stuck in low range
- 6 speed transmission swap
- CHUNK! on 1972 360 auto
- F150 "Slipping"?
- E4OD has no computer? Trouble?
- c4 or c6?
- Options to indenify specific A4LD model
- Transmission acting up.
- Cost of gear swap
- 84 ranger with the 2.8
- E4OD question
- 92' f-250 (DUALLY conversion)
- no passing gear linkage
- AOD Adjustment: gauge vs manual?
- need some advise on changin tranny fluid on 2000 ford van
- When are the front gears turning? (93 F-150)
- 79 F150 axle seal ?
- ? for the experts
- torque converter question
- Mustang
- Locker question
- F-250 Transfer Case upgrade:
- Sterling 9.75 vs. Dana 60
- Difference in gears between an HP D44 and a regular D44
- rearend help
- detroit locker Question(s)
- Tranny 70's Linc w/460
- speedo is off after rear swap
