- Any kit to make shorter manual shifts
- 02 Explorer Tranny
- 4r100 Converter (e40d)
- has anyone ever mounted a shifter to the Body ?
- C6 - BW1356 Tcase
- clutch damage
- 3:08 rear end: What does that mean
- 9" speed sensor,possible?
- Transmission won't downshift
- ATF in manual tranny
- Advice for buying 1996 Powerstroke Diesel
- Transsmissions that fit the Inline 6
- Dana 70 Left Handed Thread?
- transfer case full of automatic tranny fluid
- E4OD slamshift
- Gears
- Please Advise, which transmission?
- C6 Shift Problems
- does flushing really do the job?
- need help w/ some leaks *please*
- springs and cables on top of plenum
- a4ld problem
- trans for 289
- Borg Warner 1350 Transfer case manual
- 79 C6 Problems
- 4:10 w/4:09 ?
- 1/2 ton Solid Front Axles?
- A4LD swap questions
- converting from a c6
- 93 150 front axle/diff leaking
