Driveshaft Removal
Old Sep 24, 2005 | 11:20 AM
itsotmeel's Avatar
itsotmeel
Driveshaft Removal
It's been too long since I have "monkied" around under a Ford. I have been given a 1977 F-250 2wd automatic. It doesn't run (hence free); I need to transport it ~100mi. U-Haul (etc.) will not rent me a dolly or car carrier. I do not know anyone with a trailer/truck combo that will haul it for me without costing $250+. Thus, I conclude, I shall tow it with a tow-bar. The problem is, I can't remember how to disengage the drvieshaft, and I don't want any surprises when I get there. My two questions: (1) Do I need any specialized tool? (2) Is it relatively easy. (I seem to remember removing one on my 1970 F-100, but don't recall the details.)
Thanks for your help! And suggestions are welcomed!
Old Sep 24, 2005 | 12:42 PM
Hooker Bob's Avatar
Hooker Bob
You'll need a 7/16 wrench to remove the drive shaft from the pinion. If it's a 2 peice drive line just slide the rear section off the slip joint and your done. For a single peice I push the drive line into the tranny duct tape the rear joint then duct tape the shaft to the exhaust pipe. This way you dont drain the fluid all over the place the law kindly frowns on that.
Pat
Old Sep 24, 2005 | 07:43 PM
rclarke's Avatar
rclarke
Hooker Bob has the right info but I would make sure you have a 1/2 in wrench. All the drivelines I've pulled have 5/16 u bolts and 1/2 in nuts.
Old Sep 24, 2005 | 08:29 PM
aurgathor's Avatar
aurgathor
Also, the nuts often use 12 pts sockets.
Old Sep 25, 2005 | 04:44 PM
mikeyswood's Avatar
mikeyswood
Mine is held on with four 12-pt 1/2" bolts.
Old Sep 27, 2005 | 08:11 AM
itsotmeel's Avatar
itsotmeel
Thanks for all the good answers!
Old Sep 30, 2005 | 09:14 PM
RickPlmr's Avatar
RickPlmr
I just pulled my driveshaft out of my 99 Ranger 4x4 last night to lube the yoke splines, and never would have been able to do it without a cheater bar... which in my case was a black metal pipe I bought from Home Depot. It's 18 inches long and 3/4 inch in diameter, and fits nicely over my Craftsman socket wrence. This gave me the leverage to break loose the driveshaft bolts. You'll never get those suckers loose without something long like that to give you some leverage.
I spent an hour wrestling with my socket wrench before giving up. Came back, posted/ranted about it, and Rockledge gave me the suggestion. Popped them right off this way. Oh, and a little PB Blaster sprayed on first too helped.
Diesel Mom
Aug 26, 2013 08:17 AM
Diesel Mom
Aug 17, 2013 04:31 PM
amazngrace
Oct 26, 2008 08:04 PM
itsotmeel
Sep 26, 2005 02:32 PM
fordcountry
Mar 26, 2005 08:41 PM
