- Crankshaft/flywheel/clutch bolts
- C4 shift lever problems
- Rear end swap from 3:55 to 4:11 in 85 F-250
- Drive Line Angles
- spider gears
- C-6 Vacuum Line Question
- dana 50 identification
- My new gear set whined, what to do?
- Shifter Problem Help!!!!!
- hard shift into OD
- Yes another manual 5 spd question or 2 :) M5R1
- Broke C6...
- Ignore
- Transmission....I thought
- Help with Clutch Bleed
- E4OD + transcommand +hunting =?
- Manual hub missing parts
- E4OD fluid?
- Axle change
- F150 4x4 front differential problems
- E40D Question?
- C6 to B&W 1350
- vibration during low RPM
- E4OD shifting problem
- 91 E4OD Shift problem
- Bell Housing problems
- I cant get my truck to stop shaking!
- rear wheels locked up at 70mph
- Transmission Woes
- Changing indicator bulb on c-6 shift dial
