- Converting from 4x4 to 2x4..any thoughts?
- rebuild kits?
- How heavy is a C6?
- tranni temp gauge
- What Tranny?
- C6 won't shift until 3000+RPM
- E4OD, and YIKES!
- Is there some way to fill a dry torque converter ?
- 1982 Clark 4 speed/overdrive
- lost entire front wheel up to the axle
- NP 435 question
- Decoding the Codes
- Transmission codes
- transmission question
- E4OD to AOD swap
- whats what in c6 np205 and adapters
- 78 Transmission swap
- E4OD at around 4 or 5K RPMs
- C6 doesn't want to go when in gear
- Cruise-o-matic fluid
- I need to know my Gear Ration for 86
- clutch linkage
- Noise from clutch at low RPM
- Granny is killing me...
- C6 Dipstick
- M50D Plugs
- 4R100 problem
- C6 without kickdown lever:
- Clutch help!
- Free AOD
