I have a 1992 F-150 4x4, 302, AOD, 4.11 gears.
I am having trouble with the transmission. It has a loud squeel. It shifts ok and everything and feels fine except for the noise. The first thing I did was change the fluid. I put the truck up on jacks, and removed the rear wheels and brake drums. I put the truck in neutral and spun the driveshaft by hand and heard the squeel. So I know it's not the brakes. The gear oil is good, and the driveshaft U joints are good and freshly greased. Does anyone have any ideas?
...Welcome rpj2571, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
