76 dally driver
Old Sep 8, 2002 | 04:27 PM
jashforth's Avatar
jashforth
76 dally driver
hi guys i was looking at a 76 f-250 supper cab with a 460 automactic trans 4x2 it has 260,000 miles on it and leaks oil from the intack and oil pan the boddy is solid with a few bubles if i get them now thay wont be a problim the guy wont take less than $2500 for it it rides like a new truck it is from the south west i live in ohio do you think it would be a good truck to drive 35000 miles a year for work oh yeah it has the orinagle moter trans and every thing
Old Sep 9, 2002 | 04:03 AM
DailyDriver's Avatar
DailyDriver
76 dally driver
>do you think it
Well since you asked, here it goes. Just a little friendly advice.
As you describe it I would say no. At least I wouldn't buy it for the purpose you describe. First a 460 is a gas hog. It will suck your wallet dry. Not the best choice for a daily driver doing 35,000 miles a year IMO. Second, the truck has 260,000 miles on it already. Is that the actual miles on the engine and trans? Has either ever been rebuilt? The fact that it is leaking oil probably means that it's a high mileage engine. Could be worn out or close to it. Any blue smoke comming out the tail pipes? Do you have the time, tools, money and skills to repair as necessary, as I'm sure you will need them if this is indeed the orginal miles on the running gear. Don't forget the drive train, front end, and brakes. Are you going to use this truck for work i.e. hauling, towing, or just transportation? I would think you would want something you could depend on in either case, especialy since your lively hood depends on it. Third, $2,500. Take a good hard look at it. I would look around for other trucks that might be in better condition. If I were looking for a project truck, maybe. But for something I needed to depend on every day to use for or get to work, I would pass and look for something better.
But the choice is yours. Good luck.
Old Sep 9, 2002 | 09:56 AM
hillbillyk's Avatar
hillbillyk
76 dally driver
