Break-in?
Old Sep 9, 2002 | 07:52 PM
fordlowboy's Avatar
fordlowboy
Break-in?
hi
I was wondering how you guys would break in an engine when all of the components are new. if it was just rebuilt it would be easy but it has a new carb, igintion, cam ext.. and i heard if you don't break in properly, it could be hard on the valve train and bearings. (460) I'm not sure if all of the new components will work right with out the engine dieing and restarting while adjusting stuff. thanks for any help.
Old Sep 9, 2002 | 10:05 PM
masterbeavis's Avatar
masterbeavis
Break-in?
If you install a new cam, you need to:
prime the motor (use a 5/16"-1/4" drive socket and a 12" extension, use a drill with a 1/2" chuck. turn it counter clockwise)
Set the timing on the dampner, compression stroke
put the dizzy in on the #1 cyl
crank er up.
If it wont start, try turning the dizzy about 5-10 degrees till it starts
once it starts, hold the throttle above 2000 rpms for about 10 minutes. Vary the motor speed about 3-400 rpms.
Do a search, you will find more information
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old Sep 9, 2002 | 10:15 PM
LxMan1's Avatar
LxMan1
Break-in?
Actually 20 min. on the cam is recommended by the cam manufaturers. It is ok to shut it off during this period, but don't let it idle until after a full 20 min. of run time at 2000 rpm or more. This is how to ensure proper lube from oil splashing off of the crank onto the camshaft during break-in.
Once that is done, just drive it normal for about 500 miles, but don't stay at a steady speed. The loading and unloading of the engine will help the rings seat better, Then change the oil and filter, to remove anything left in the block, then rock on. You are done.
Jimmy
Old Sep 9, 2002 | 10:19 PM
LxMan1's Avatar
LxMan1
Break-in?
