Engine vibrations at idle
Old Sep 8, 2002 | 10:17 PM
LxMan1's Avatar
LxMan1
Old Sep 11, 2002 | 10:46 PM
LaDANO's Avatar
LaDANO
My 79 has been giving me fits with a rough vibration at idle. I've double checked ignition and vacum 17lbs steady, but still very rough till about 2000 rpm's. I've changed balancer (used) and still nothing I need some helpful input. Thanx Dan
Old Sep 12, 2002 | 08:42 AM
Vampiro's Avatar
Vampiro
maybe engine or tranny mounts need replaceing
Old Sep 12, 2002 | 11:16 AM
loudfords's Avatar
loudfords
Do you have the dowel pins installed between the engine & tranny? My 79 didn't when I bought it, and it had some horrible vibrations.
Old Sep 12, 2002 | 11:44 AM
LxMan1's Avatar
LxMan1
For a stock motor, 17 is kinda low. Should be around 20. Could be a vacuum leak, or a carb. problem. Sounds like it's running lean and the throttle plate is open kinda far to keep it running. That would explain the low vacuum. My 460 with an oversized cam has 18" and it had about 20.5" with the stock cam.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
