95 Explorer running cold
Old Nov 7, 2004 | 03:15 PM
DGGRAHAM's Avatar
DGGRAHAM
I last posted March of this year.
I have tried Stant, Ford and now I have a 198 deg. Moto-rad stat, all with the same result. Normal highway temp is around 170f. This summer I was getting 28mpg on long trips-4-6 hour run. Back and forth to work was 24 mpg.
106k round trip. This is more than acceptable.
But, winter is here and low temp equals low heater output. I'm going to install a winter front and see if that helps.
Thanks for the sugestions in March
Old Nov 8, 2004 | 11:55 AM
mrshorty's Avatar
mrshorty
How are you determining that the engine is running cold? Dash gauge? Aftermarket gauge? ECT? Temperature from heater vents?
Old Nov 8, 2004 | 12:46 PM
Backin72's Avatar
Backin72
I went through 2 t-stats with the 3rd one finally working correctly.
Old Nov 8, 2004 | 06:50 PM
DGGRAHAM's Avatar
DGGRAHAM
mrshorty,
I'm using an infrared thermometer and aiming the lazer right on the housing shere the t/stat is.
NICKSAN
Nov 20, 2015 08:32 PM
Plain Jane
Nov 15, 2015 08:54 PM
happscrap
Nov 24, 2014 07:43 PM
jsw0767
Oct 14, 2014 06:06 AM
Iaff113
Feb 15, 2014 11:56 AM
