Flasher/ turn signal problem
Old Nov 9, 2004 | 12:25 PM
David Ochoa's Avatar
David Ochoa
Got a 98 Explorer, neither of the turn signals nor the hazard signals work. Checked bulbs and fuses, there OK, but I was looking for the hazard flasher itself and cna't locate it and the owners manual isn't much help. Any ideas?
Old Nov 9, 2004 | 12:34 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Moved to Explorer forum.
Old Nov 9, 2004 | 02:10 PM
87 XLT's Avatar
87 XLT
If it's the same as a 97 it will be near the brake light switch
Old Nov 9, 2004 | 04:33 PM
e-manfive's Avatar
e-manfive
Flasher/turn Sig Reply
i have a 95 ex,had a similer prob with my rt turn sig buzzing when turned on. checked fuses,flashers etc,all were good. turns out it was my sig switch itself,easy to replace,once you take off steering collom covers. check that & see if that helps. also on my 95 the whole switch included the flasher switch too.good luck
compwrench
1997 - 2003 F150
Jun 25, 2012 04:45 PM
BuckHammer
15
Mar 11, 2011 07:51 AM
Supercab
Aug 20, 2006 03:23 PM
silverbullet99
1978 - 1996 Big Bronco
Jan 13, 2004 05:12 PM
montangrunt
Aug 12, 2003 07:56 AM
