howls under left pressure
Old Jan 18, 2010 | 12:13 PM
kwaskow's Avatar
kwaskow
My 2003 Mountineer will make a slight howling noise, at highway speeds when I veere leftward only. Thinkning wheel bearing....any other ideas?
Old Jan 18, 2010 | 12:30 PM
shorod's Avatar
shorod
I'd suspect wheel bearing as well, but I'd start by rotating tires to see if the noise changes. Also make sure all four tires are properly inflated. Start with the inexpensive options first.
-Rod
Old Jan 19, 2010 | 06:47 AM
kevincw's Avatar
kevincw
I have the same noise. I changed the left hub and the noise is still there. I'm going to rotate the tires like shorod said. While the wheel is off I'll check the right hub.
Old Jan 19, 2010 | 08:23 AM
kwaskow's Avatar
kwaskow
Please repost with your results!
Old Jan 19, 2010 | 09:19 AM
kevincw's Avatar
kevincw
I will let you know the outcome.
lm65jr
Oct 27, 2012 12:37 PM
yellar
2004 - 2008 F150
Jul 5, 2009 12:46 PM
aaronhuck
Jun 23, 2006 03:43 PM
Detret
Jul 28, 2004 09:38 AM
wpcol
Sep 8, 2001 06:34 PM
