4wd Non-Functional on First Generation Explorer
Old Jan 18, 2010 | 08:26 PM
RiverRatMatt's Avatar
RiverRatMatt
Hey, I have a friend with a First Generation Explorer (can't remember what year) whose 4wd system does not work. Apparently he didn't use it for a while, and when he tried to engage it, it just wouldn't go. He took it to a shop and they quoted him something like $2500 to fix it, and when he declined they apparently 'just wired it up.'
I took a look underneath the truck, the front drive shaft is in place and normal, everything looks OK. I asked one of my friends and they said a likely cause might be the 4wd engagement motor that sits toward the back of the transfer case, but that's only a $100 part. Could that be it and they were just overcharging for labor? What do I need to know about replacing that motor if it is the problem?
Thanks!
Old Jan 18, 2010 | 10:10 PM
mrshorty's Avatar
mrshorty
1st gen is '91-'94, just so we can be sure it is a 1st gen explorer.
Shift motor is indeed a common problem on these. It's common enough that there are a couple of different web-sites that describe how to remove, clean, and "rebuild" the shift motor.
The other thing that frequently fails on these is the auto hubs. You might double check to see if the problem is in the transfer case or the hubs, but almost all 4wd problems on the first gens are one of those two problems.
Old Jan 18, 2010 | 10:19 PM
RiverRatMatt
Ok, I thought it might also be the auto hubs. Any idea on how I could check? I do have access to read vehicle codes if that would help
Old Jan 19, 2010 | 09:17 AM
mrshorty's Avatar
mrshorty
First thing I'd look at is: is the 4x4 light coming on when you push the button? If yes, then the transfer case is probably shifting right. If no, then the transfer case probably isn't shifting.
Next check would be to pick up the front end, crawl under and rotate the front driveshaft with the t-case in 2H and after trying to shift into 4H. In 4H, the front drivetrain should not be able to move, but it should be free in 2H. The rotation of the axleshafts as you rotate the driveshaft should cause the hubs to engage, so you can get an indication of whether the hubs are working.
Old Jan 20, 2010 | 03:57 PM
RiverRatMatt
I looked at the truck today, the problem isn't the 4wd shift motor, it is in the hubs.
Basically what happens is they will engage, but while driving they'll pop out and then re-engage. Can this be solved by cleaning and re-lubricating them? Can anyone link me to a walk-through with pictures?
Old Jan 20, 2010 | 07:16 PM
aquanaut20's Avatar
aquanaut20
Once engaged the hubs should not disengage, it requires reversing the vehicle to do that, the hubs work on a ramp system, the drive shaft drives a selector up a ramp to engage forward, when reversing the mechanism unramps and re ramps in the opposite direction. To disengage the 4X4, selecting 2wd sets the tranfer case in the neutral position (no front drive Pressure) and when the wheels first move in the opposite direction the hubs unramp and remain in N (freewheel)
The biggest issue with the auto hubs is too much and/or old hard grease.
The fix: remove the AUTO hub, wash out all old grease, lightly coat the splines with grease that will not harden in low temp, add 1oz of ATF, reinstall with new gasket or good Silicone seal, they should work flawlessly. We have used this method down to -52*.
The second option, install manual hubs.
Old Jan 21, 2010 | 06:08 PM
RiverRatMatt
Thank you! Just to be 100% clear, ATF = Auto Transmission Fluid yeah?
Old Jan 21, 2010 | 07:04 PM
aquanaut20's Avatar
aquanaut20
Yes, it gets into the tough places as the wheel turns, (Just like gargling), use a brush and paint the grease on, light coat.
Old Jan 22, 2010 | 03:18 PM
RiverRatMatt
Alrighty, no problem!
By the way, you mention it being a ramping system.. the symptom he is describing is he'll be driving in 4wd, and then there will be a loud 'BAM' kind of sound and the truck will shake a little because of it. So I'm thinking the hubs are not engaging properly?
Old Jan 22, 2010 | 07:50 PM
aquanaut20's Avatar
aquanaut20
The gear that ramps cannot compress the old/hard grease, it cannot slide into position to lock hub properly....
if it is driven like this it just might eat the splines.....
Old Jan 22, 2010 | 08:07 PM
RiverRatMatt
Yeah, he hasn't been using the 4wd. Was going to fix it today, but looks like I'll probably be doing it tomorrow. Will let you know the outcome! Thank you for all your help!
Old Mar 26, 2010 | 07:34 PM
nitrogen's Avatar
nitrogen
its possible if they have kicked out more than a couple times the hub mechanism can be toast. little plastic parts break. find a set at the wrecking yard, manual ones seem to go almost forever
granny_rocket
Jul 14, 2014 07:42 AM
Sand_Man
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 23, 2014 07:45 PM
JustSomeDude
May 17, 2006 01:18 PM
Donald Rohret
Jan 19, 2006 06:10 PM
ARTURO TOSCANO
Aug 19, 2002 12:43 PM
