Elecectrical Question? daytime running lights?
Old Jan 20, 2010 | 07:26 PM
bronkntrukholik's Avatar
bronkntrukholik
I have a '98 explorer, up until a cupl days ago, when I had the ignition on the daytime running lamps wopuld come on, now they aren't working and when the key is off, and the light are also off, the high beam light on the instrument cluster stays on all day and night, when the lights are turned on, the high beam light works properly on high beam and goes out with low beam! Any possible ideas where to start or to look at?
Old Jan 20, 2010 | 08:03 PM
scucci's Avatar
scucci
DRL module under the drivers side front bumper seems to cause a lot of trouble.
Old Jan 20, 2010 | 09:36 PM
bronkntrukholik
Ill have to check that out! Is there any way to check that or is it best to replace it? If a replacement is best, does the average autoparts store carry it or is it a FORD only part? Thank You for your help!
Old Jan 20, 2010 | 10:13 PM
scucci's Avatar
scucci
Here is the symptom chart for DRL diagnosis. It is impossible to copy all the pin point tests unfortunatly. Also here are some prices online. Try Auto salvage yard?
Rockauto parts online:
DORMAN Part # 704201 {OE Solutions}
Module $47.99
Ford online parts:
Fast Parts Network - Home
Control assy 95-98 $148.00 your cost $119.80
The Daytime Running Lamps are Inoperative:
Fuse(s).
Circuitry.
Park Brake Switch.
DRL Module
The High Beam Indicator is On, High Beams at Full Intensity with Headlamps OFF:
Circuitry.
DRL Module
The Daytime Running Lamps are On With the Ignition Switch OFF:
Circuitry.
Ignition Switch.
DRL Module
The Daytime Running Lamps are On With the Parking Brake Set:
Circuitry.
Park Brake Switch.
Park Brake Switch Bracket.
DRL Module
The Daytime Running Lamps are Inoperative - High Beams On at Reduced Intensity With the: Headlamp Switch ON
Circuitry.
DRL Module
No High Beam Indicator In High Beam Mode
Bulb.
Circuitry.
DRL Module
check:
Power Distribution Box Mini-Fuse 4 (15A)
Fuse Junction Panel Fuse 27 (15A)
PINPOINT TEST B: HIGH BEAM INDICATOR IS ON, HIGH BEAMS AT FULL INTENSITY WITH HEADLAMPS OFF
Place the headlamp switch in the OFF position
Is the high beam indicator ON?
Yes
REPLACE the DRL module. TEST the system for normal operation.
No
GO to B2 .
B2 CHECK HIGH BEAM OPERATION
Observe the headlamp high beams.
Are the high beams ON at full intensity?
Yes
No
GO to B3 .
B3 CHECK THE LOW BEAM INPUT
Measure the voltage between DRL module C134-6, circuit 12 (LG/BK), and ground.
Is the voltage greater than 10 volts?
Yes
REPAIR circuit 12 (LG/BK). TEST the system for normal operation.
No
Yes
No
REPLACE the DRL module; REFER to Module . TEST the system for normal operation.
PINPOINT TEST E: THE DAYTIME RUNNING LAMPS ARE INOPERATIVE - HIGH BEAMS ON AT REDUCED INTENSITY WITH THE HEADLAMP SWITCH ON
CHECK THE VOLTAGE TO THE DRL MODULE
Measure the voltage between DRL module C134-6, circuit 1056 (DB/LG), and ground.
Yes
No
REFER to Section 417-01 lighting diags .
PINPOINT TEST F: NO HIGH BEAM INDICATOR IN HIGH BEAM MODE
Place the multi-function switch in the high beam position.
Connect a jumper wire between DRL module C-134-8, circuit 12 (LG/BK), and DRL module C-134-1, circuit 932 (GY/W).
Does the high beam indicator illuminate?
Yes
No
REFER to Section 413-01 lighting diags .
Old Jan 21, 2010 | 07:00 PM
bronkntrukholik
Thank you very much, that info that you provided was very helpful. I unplugged the module for now and the lights are working with the switch as they should, I am gonna hit up a local salvage yard to pick up a used one.
olek
Electrical Systems/Wiring
Nov 24, 2023 01:33 PM
speedracer29j
Mar 17, 2017 11:07 AM
dh1200
Jul 23, 2016 04:37 AM
Animalv
Nov 1, 2014 07:59 PM
Steve98592
Dec 16, 2004 02:59 PM
